  • July 18, 2025, 10:45:02 AM
Author Topic: MVVS  (Read 1392 times)
Offline Garf
    • Hangar Flying
MVVS
« on: October 22, 2011, 07:16:35 PM »
Has anyone seen this version of the MVVS?
Offline PerttiMe
Re: MVVS
« Reply #1 on: October 23, 2011, 04:43:50 AM »
There was a ".45 or .49" question on RCU, a while a go:
http://www.rcuniverse.com/forum/m_10685609/tm.htm
and the expert answer was:
Those with the 'blank' circle were mostly .45 engines.
The .49 engine usually had a 'figure 8' machined there.
Most .49 engines had a green anodized head (.45 engines had a red anodized head), but that was before most engines got the blue anodized head (and prop-driver).
The only way to be sure is to measure the stroke.
The .45 had a 19.6 mm stroke, while the larger engine had a 21 mm stroke.
You can measure the stroke through the glow-plug hole; no need do disassemble.
Offline Igor Burger
Re: MVVS
« Reply #2 on: October 23, 2011, 05:40:39 PM »
It is usual GFS engine ... could be 6,5 or 7,2 or 8 ccm.
this looks like classic 6,5 (0.40 cu inch)
Offline Garf
    • Hangar Flying
Re: MVVS
« Reply #3 on: October 23, 2011, 09:42:47 PM »
All I can say positively is that it takes the same front bearing as the ST G21 46.
