The tapered leading edge is called leading edge sweep. it helps with a model when cornering, and a basic aerodynamic theory says that leading edge sweep helps with stability. Through the years there have been varying amounts in designs, and there are lots of models with constant chord wings that turn just fine. You can build any one or all three and be assured that they wili perform quite nicely.
