  • June 25, 2025, 09:33:15 PM
Author Topic: ...venturi size...  (Read 1231 times)
Offline Bootlegger
...venturi size...
« on: March 15, 2007, 10:45:23 AM »
 Mornin fellow's,
  I have a Ringmaster that is powered by an OS 25 FP, with a .250 venturi, I am lookin for suggestions as to what size venturi will be better.
  The fuel is Powermaster 5% with 22% oil (half & half) a Thunderbolt long plug w/idlebar and a 9x5 APC prop line length is 58' eyelet to eyelet.
  Probably around 10,200 or there about  R P M range...
  Thanks again Sparkey for this site... D>K #^ #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ...venturi size...
« Reply #1 on: March 15, 2007, 12:38:53 PM »
Hi Gil,
What do you want it to do different?  Have you tried it?  Not trying to be a smart alec, just not sure of the question.............
Bill <><
Offline Steve Holt
« Reply #2 on: March 15, 2007, 03:26:29 PM »
The FP25 on my ARF Streak has the same venturi, an OS needle valve assembly, and the OS 2030 muffler.  Tank is a 3 oz Hayes clunk on muffler pressure.  On a 9X4 APC prop I set about 12,500 rpm on the ground.  Works well here in Tucson on 60' lines.  Fuel is 10% nito, 22% oil (half castor and half syn.).  I have used the same set-up on a Ringmaster with good results.  If it is too fast on 60' lines, try 63'.
