  • July 18, 2025, 06:02:26 AM
Author Topic: muffler O-ring recommendation  (Read 1226 times)
« on: September 20, 2023, 07:58:02 PM »
My muffler O-ring is going south.  Is there a special kind of O-ring to be used or are their some specifications of type of O-ring for this muffler environment?  It's a PA-61 RE.
Thanks!
Online Robert Zambelli
Re: muffler O-ring recommendation
« Reply #1 on: September 21, 2023, 05:51:30 AM »
Scott: try McMaster-Carr.
They carry a huge assortment of o-rings, including high temperature.
« Reply #2 on: September 21, 2023, 07:06:31 AM »
Thanks!
« Reply #3 on: September 21, 2023, 01:33:04 PM »
 You want a high temp O-ring  and these are usually a red colored silicone, at least in industrial use in my experience. Some good hardware stores carry a good variety of o-rings, along with good auto parts stores. An industrial power transmission parts and supply place will carry them also and most will sell to walk in traffic in small quantity.
« Reply #4 on: September 21, 2023, 04:44:49 PM »
This chart may help, although for guys who memorized the trade names, the symbol system may cause you to have to looks things up....
https://www.gallagherseals.com/pub/media/magefan_blog/2015/11/templimits.jpg
My first thought was Viton, if you weren't getting long enough life out of a silicone seal.
Offline Lauri Malila
« Reply #5 on: September 23, 2023, 01:39:09 AM »
Silicone O-rings seal well but cannot always tolerate the mechanical loads. Viton is stronger and harder but it tends to permanently deform and harden under heat & compression.
So, both will work when done correctly. In both cases, I'd recommend replacing the O-ring with a new one every time you dismantle the system.
also, when you re-assemble the engine/muffler, it's a good thing to wrap a couple of layers of thin PTFE plumbing tape around the O-rings.
I make my own muffler adapters with 2 O-rings; the first (closer to engine) in Viton and the second in silicone. Viton takes the pressure loads, and silicone protects the Viton from direct contact with hot gases. L
