  • July 18, 2025, 02:24:59 AM
Author Topic: muffler O-ring recommendation  (Read 1224 times)
« on: September 20, 2023, 07:58:02 PM »
My muffler O-ring is going south.  Is there a special kind of O-ring to be used or are their some specifications of type of O-ring for this muffler environment?  It's a PA-61 RE.
Thanks!
Offline Robert Zambelli
Re: muffler O-ring recommendation
« Reply #1 on: September 21, 2023, 05:51:30 AM »
Scott: try McMaster-Carr.
They carry a huge assortment of o-rings, including high temperature.
« Reply #2 on: September 21, 2023, 07:06:31 AM »
Thanks!
« Reply #3 on: September 21, 2023, 01:33:04 PM »
 You want a high temp O-ring  and these are usually a red colored silicone, at least in industrial use in my experience. Some good hardware stores carry a good variety of o-rings, along with good auto parts stores. An industrial power transmission parts and supply place will carry them also and most will sell to walk in traffic in small quantity.
Online Dave Hull
« Reply #4 on: September 21, 2023, 04:44:49 PM »
This chart may help, although for guys who memorized the trade names, the symbol system may cause you to have to looks things up....
https://www.gallagherseals.com/pub/media/magefan_blog/2015/11/templimits.jpg
My first thought was Viton, if you weren't getting long enough life out of a silicone seal.
Offline Lauri Malila
« Reply #5 on: September 23, 2023, 01:39:09 AM »
Silicone O-rings seal well but cannot always tolerate the mechanical loads. Viton is stronger and harder but it tends to permanently deform and harden under heat & compression.
So, both will work when done correctly. In both cases, I'd recommend replacing the O-ring with a new one every time you dismantle the system.
also, when you re-assemble the engine/muffler, it's a good thing to wrap a couple of layers of thin PTFE plumbing tape around the O-rings.
I make my own muffler adapters with 2 O-rings; the first (closer to engine) in Viton and the second in silicone. Viton takes the pressure loads, and silicone protects the Viton from direct contact with hot gases. L
