  • July 18, 2025, 03:19:02 AM
Author Topic: Muffler discovery  (Read 2915 times)
Offline Gary Dowler
Muffler discovery
« on: February 01, 2019, 01:36:03 AM »
Just found out tonight that a OS 2030 muffler fits perfectly on a K&B 40 engine.
I'm probably the 73rd guy in here to figure it out, but I thought it was a neat find.
Gary
Offline Perry Rose
Re: Muffler discovery
« Reply #1 on: February 01, 2019, 05:12:44 AM »
The 843 that comes with the .25LA has the same bolt spacing as the Stalker .51. side exhaust.
Offline Mark Messmer
« Reply #2 on: February 01, 2019, 05:39:29 AM »
The Brodak 40 muffler fits the Max 40 and 45 FSR  and also the HP 40 .
Offline ericrule
« Reply #3 on: February 01, 2019, 09:26:56 AM »
Bolt spacing is 1.25" so it also fits the OS Max 35S. At RSM ?Distribution we have been manufacturing a tongue muffler weighing 0.02 oz for over 20 years.
Offline Paul Walker
« Reply #4 on: February 01, 2019, 10:24:39 AM »
OK Eric, I know you are good. But really, a 0.02 ounce muffler.
Are you sure you didn't slip a digit somewhere???
Offline ericrule
« Reply #5 on: February 01, 2019, 11:35:22 AM »
Mr. Walker, sir. You are correct.
I am good but really OLD! What's a zero or two between friends?
The correct weight of the muffler is 2/10 oz. The weight should read 0.2 oz
Offline Ara Dedekian
  • Ara Dedekian
« Reply #6 on: February 01, 2019, 12:11:16 PM »
        An OS 762 muffler is an exact match to the spacing on a Fox 35. For convenience, I've run a 4/40 tap into an already tapped (metric) OS muffler and use 4/40 bolts. It works quite well, but it looks like I kept the metric threads on this one.
        Ara
Offline Perry Rose
« Reply #7 on: February 03, 2019, 05:25:43 AM »
And the Fox .35 muffler fits the O.S. .40/.46 LA's
« Reply #8 on: February 08, 2019, 12:10:41 PM »
The OS .40/.46LA muffler fits and works really well on a Magnum XLS .36 (or XLS .32, I suppose).  y1 Steve
Offline Phil Spillman
« Reply #9 on: February 10, 2019, 08:58:12 PM »
I have found this segment quite interesting! Which of these or other tube mufflers will mate up with an ST G21 .40/ .46? Can anyone please help me with this dilemma?
Phil Spillman
Phil Spillman
« Reply #10 on: February 10, 2019, 09:15:12 PM »
        Ara
Those "small ears" Foxes won't take any beating at all.  Later Foxes had the full length ears.
« Reply #11 on: February 11, 2019, 12:13:18 PM »
Phil Spillman
The ST G.21 .40/.46, ST G.51 and ST .60bb all are supposed to be the same bolt pattern. FLOW is another subject. I would not expect good results from a .40 muffler on a G.51 or .60bb.
One of my models flew originally with a Royal .45, then ST G.51 that was drilled for two extra bolts. I came by a used GMA Magnum XL .53 and put it in that model. The mounting bolts matched up with the Royal pattern perfectly. A little fiddling with the notch for NV, and used the same ST muffler as the G.51 (a Randy Aero CNC tube muffler with 4-40 bolts). This doesn't guarantee that a Magnum muffler would fit, because of the 3mm screws being bigger than the 4-40's, but if one was to put 4-40 helicoils in the Magnum muffler, it would probably work ok. But their mufflers are pretty hefty things now, tho not as bad as the OS mufflers. But if you need nose weight....  y1 Steve
Offline Ron Varnas
« Reply #12 on: February 12, 2019, 02:22:30 AM »
Interesting thread  ;D anyone know an alternative  muffler that would fit the Moki 51 stunt ?
As I've had no success hunting down a factory one pictured  :'(
RJV Melb. Australia
Offline Paul Wescott
« Reply #13 on: February 15, 2019, 06:18:34 PM »
What is the mount hole spacing on your Moki 51?
« Reply #14 on: February 15, 2019, 09:36:09 PM »
If its 28 M.M. the *^%#! FSR OS / HP  ( and an Enya ) ones'd match .
The Toungue ( C.S.C. ) is rowdie but runs superior , In my experiance .
Thisisa ' pirate ' copy .
Has three holes ( 6 mm ? = depth of OS Exhaust ) in a block of Alloy , with three slots catching them ( half depth ) outlets .
Need to grind a bits end flat , really . to get the end bit . Three holes bored thru. NOT a rectangle ..
Anyone got a real one - I'd like it , or  trade / etc .
