  • June 17, 2025, 11:32:27 PM
Author Topic: Dawn power dissolver  (Read 2212 times)
Online Robert Zambelli
Re: Dawn power dissolver
« Reply #1 on: September 20, 2016, 03:47:20 PM »
Warning Caution... if you use  Dawn power Dissolve, be sure to completly disassemble  and thoroughly rinse then OIL  ALL Parts
Power Dissolve  will corrode the aluminum and Rust the bearings and any steel
Randy Smith
Offline Mike Griffin
« Reply #2 on: September 20, 2016, 09:00:46 PM »
It aint $47.00 good Bob.
Offline Ara Dedekian
  • Ara Dedekian
« Reply #3 on: September 21, 2016, 05:43:19 AM »
Yep it's that good, But the ebay bottle is a rip off. They merely changed the name and now it is found in the industrial section of cleaning products vs kitchen/bathroom cleaning products. I forget the new name, but same stuff. different label. Loop holes exist even for the screwy EPA. H^^
        Ty
           Thanks for letting us know about the name change. I'm down to my last few bottles and thought it was gone forever. It is that good!
          Hoppe's sells a gun cleaner (Hoppe's No. 9?) that Davis Diesel used to sell as an engine cleaner that works well also.
        Ara
« Reply #4 on: September 21, 2016, 08:18:08 AM »
Its  $54.00    shipped!!!1
Offline BillLee
« Reply #5 on: September 21, 2016, 09:57:45 AM »
Oh, good grief!
Didn't ANYbody look at the "People were also interested in"?
Bill Lee
AMA 20018
« Reply #6 on: September 21, 2016, 10:06:27 AM »
I'll stay with the old crock pot procedure.
« Reply #7 on: September 21, 2016, 10:19:00 AM »
Yes.  If you want to clean crud from engines, the old crock pot with antifreeze is still the best.  For cleaning up your models, some people use "Sprayway" .  I normally use good old dishwashing liquid and a pan of water. Doesn't cost me anything.
Offline Tony Drago
« Reply #8 on: September 21, 2016, 02:25:29 PM »
Ty, Could this be it.
http://www.ebay.com/itm/DAWN-Professional-6-00-Power-Grease-Dissolver-32-fl-Oz-Ready-to-Use-Spray-NEW-/282148176112?hash=item41b15780f0
« Reply #9 on: September 21, 2016, 07:02:45 PM »
I recently pulled the engine out of my 1967 ALFA - the first time it's ever been out.
You can imagine the amount of dirt, oil, grease and other crud embalming it, the gearbox and the engine compartment after 100,000 miles.
I found a bottle of Power Dissolver in my garage, spayed it on and couldn't believe the results.
The Dissolver cut through it like magic.
I hope I can find a comparable product.
Check out the pictures and see (before and after)
