Thanks Ted. Just out of curiosity, what grit sandpaper do you use?
MIke
Mike,
I put paper on both sides of the board (generally a four foot long generic shelf board from OSH or Lowes--I depended on clamping them to the flat building table to remove any bow, etc.), a medium grit for the first few passes to get the surface generally flat and then a fine grit for the obvious reasons. Because I built reasonably carefully I didn't usually have to remove a lot of material so the grits are probably something like 120 and 320. I also have some shorter boards with coarser grit to take care of more "manly" operations than require rapid removal of lots of wood.
My favorite papers for bare wood were from 3M and were labled as "Fre-Cut" and "Open Coat". They're readily identifiable by their grit colors: Light green for coarser grits, a cabernet wine color for medium grits and sort of a yellow/tan for finer cuts.
FWIW, I use(d) these boards religiously for almost any kind of "part shaping" (such as rounding off blanks for tips, stabs, rudders, etc)sanding as they allow you to move the part over the paper rather than try to hold the part in one hand and the paper in the other. Curved surfaces are, of course, a different animal. Sanding of fuse blocks and cowls frequently bring out the "shoeshine man" in me. I'll rough the radius of the blocks by "counting strokes" of the razor plane symmetrically and then use a foot long (by a width appropriate) strip of sandpaper as though buffing out the gloss on the toes of your go to meetin' wingtips (shoes, that is). The counting "plane strokes" and "buffing your shoes" approach resulted in very acceptable curve symmetry and I never bothered to use templates when shaping.
As an aside, I've got a dozen or so blue foam sanding blocks (~2" X 10" and roughly 3/4" thick) to which I use double sided tape to apply sandpaper to both sides and employ long t-bar aluminum blocks for things like evening out planking and cap strips, etc.
Don't know what got me started but...
Super glue is the greatest thing that ever happened to sanding. I have literally dozens of wierd shaped sanding tools I've manufactured literally no time at all to do special jobs. Paper on dowels is just the starting point. let your imagination run rampant when building and you'll find yourself doing it all the time.
Ted
Allan Perret. Just read your post submitted while I was writing this. I love the square tube approach! It pretty much self flattens itself and doesn't require multiple individual units that have to be removed, stored and replaced by the one you need at the moment. Yes, the melanine covered shelving is exactly what I used. I should have mentioned that I don't use 12" shelves, just the eight inch versions.
