Other than submersing dirty engines in Antifreeze in a crockpot, what products and methods do you use to clean dirty engines?
Thanks in advance for your replies.
If it is baked-on nothing comes close to crock pot and antifreeze for cleaning ability and safety (to the engine). All the chemical cleaners entail significant chance of damage or staining.
If it's loose debris and oil, on the outside then almost anything that will remove oil will work. My favorite is isopropyl alcohol and an old toothbrush. Acetone or lacquer thinner will work about as well, but IPA is really inexpensive and relatively safe. Rubbing alcohol from the grocery store is 79 cents a pint. There's very little that lacquer thinner will remove that alcohol won't, aside from paint.
Everybody will cringe, but when disassembling engines and cleaning them, laundry detergent and hot running water works awfully well, as long as you dry it out and oil it promptly. Running water is great because it washes away the debris so there is little chance of just pushing it around with a toothbrush/whatever, and laundry detergent is a very powerful cleaner for any covalent-bonded substances like oil. Boiling water/layndry detergent is probably the next best thing to crock-potting, but there is a chance of staining and corrosion, just because good old liquid Tide is pretty stout stuff. It's far and away the best thing to use for washing your hands after working on cars, much better than Go-Jo, etc.
