  • June 24, 2025, 11:29:31 PM
Author Topic: Motivation to build  (Read 2059 times)
Offline James Mills
Motivation to build
« on: August 22, 2019, 09:12:49 PM »
I have to admit that I'm one of those people who struggles at time to find the necessary motivation to get into the shop at night and build.  This past weekend at the Paducah contest (sadly the final contest) I found my motivation to get back in the build room.  The ground always wins  HB~> #^
James
AMA 491167
Online Crist Rigotti
Re: Motivation to build
« Reply #1 on: August 23, 2019, 12:08:14 AM »
Ouch!
« Reply #2 on: August 23, 2019, 05:22:59 AM »
Long cold winters are made for that... :-\
Offline Peter in Fairfax, VA
« Reply #3 on: August 23, 2019, 06:15:53 AM »
Going to rebuild?  Looks possible.
« Reply #4 on: August 23, 2019, 09:15:36 AM »
That looks bad.  You did save all the pieces, right?   I have one that is in final finish stage but physical problems have kept me out of shop.  Now have to wear back brace to use riding mower and canes also. D>K
« Reply #5 on: August 23, 2019, 09:55:44 AM »
Doc build a nice scale ship-we'll find a pilot for you.
« Reply #6 on: August 23, 2019, 10:15:13 AM »
It is always sad to see one our works of passion get broken but I want you to look at the damage to the wing.  I have had two "close encounters of the asphalt kind" with my electrics and both times the nose pulverized and the wing survived virtually undamaged.  Please fix this one.  It is too pretty to sit in a corner.
ken
Offline Paul Walker
« Reply #7 on: August 23, 2019, 06:09:33 PM »
OK James....no more monkey see, monkey do.
Sorry to see your pretty plane "scratched".
As in scratched out of existence.
Sorry to see.
Offline Tom Luciano
« Reply #8 on: August 23, 2019, 06:16:48 PM »
Sorry to see James. That was a sharp looking plane.
Tom
AMA 13001
« Reply #9 on: August 23, 2019, 07:22:10 PM »
James.      I have rebuilt a few like that.  Here is big time saver.    When taking the old body off the wing do not cut it off down at the planking. Cut it 1/8” above the planking all around the wing. Cut the new body sides wing opening 1/8 larger. This is vey easy and if you put the wing in from the bottom and it is fast.
EddyR
« Reply #10 on: August 24, 2019, 11:06:04 AM »
That is why I have built combat wings lately and sport stunt.   No pattern, just loops and eights.  By the way I do have a profile scale plane I would like to get to and my profile carrier with RC throttle control is good so I can slow it down. D>K
Offline Matt Neumann
« Reply #11 on: August 24, 2019, 02:52:43 PM »
As we discussed last week, the flying surfaces do look like you can put them in a new fuselage.  If it were me I would do that.  Plus make a back up just in case.  But the wing and tail did look quite solid.  Still interesting that I found the motor a good 20 yards in front of the wreckage.  You are lucky it went in on soft dirt.  Otherwise the flying surfaces would not be salvageable.   That big divot you put in the ground probably saved the flying surfaces.
Matt Neumann
Offline James Mills
« Reply #12 on: August 24, 2019, 05:12:52 PM »
I think the wing will be okay, the stab is broken.  The motor and spinner actually came out unscathed, I'm glad you found it.  After the Team Trials I'll get back to the new Triumph and get it finished.
James
AMA 491167
Offline James Mills
« Reply #13 on: August 24, 2019, 05:14:27 PM »
We picked up as many pieces as we could.  The parts are in a bag in the garage at the moment.
James
AMA 491167
Offline James Mills
« Reply #14 on: August 24, 2019, 05:16:25 PM »
Tom
Thanks Tom.  Ironically I was trying to decide if I wanted to refinish it or not, the decision is prettty easy now  #^.
James
AMA 491167
Offline James Mills
« Reply #15 on: August 24, 2019, 05:17:42 PM »
Looks like the wing is salvable.
James
AMA 491167
Offline James Mills
« Reply #16 on: August 24, 2019, 05:19:05 PM »
EddyR
James
AMA 491167
