  • July 17, 2025, 03:24:26 PM
Author Topic: Some kind of record  (Read 675 times)
Offline johnt4051
    • Flying Lines
Some kind of record
« on: May 23, 2021, 01:02:15 PM »
In sports, they keep records and stats on everything.  In our hobby, not so much.  Therefore, I can claim a record without having to prove it.
On Saturday, I set the world record for the largest difference in weight of two CL airplanes flown on the same day.
I started the day flying my Wee Wun, a British-designed plane with a 15-1/2-inch wingspan and a total flying weight of 2-3/8 oz.  Power is a Cox .010.  I built it to prove that you could build a stuntable plane for an .010.  It stunts.
Later in the day, I flew my Crossfire, a 65-oz. electric PA plane.
That is a difference of 62-5/8 oz., if my math is correct.
Do I get a certificate, or a trophy, or something?
John Thompson
Flying Lines
Offline pmackenzie
  • Pat MacKenzie
Re: Some kind of record
« Reply #1 on: May 23, 2021, 01:24:49 PM »
That Wee Wun is pretty cool, I have both an .010 and an .020 that could use a ride......
https://outerzone.co.uk/plan_details.asp?ID=6041
MAAC 8177
Offline johnt4051
    • Flying Lines
« Reply #2 on: May 23, 2021, 05:23:57 PM »
If you build a Wee Wun for .010, make the nose 1/2" longer and move the leadouts back a little from the plans.
John Thompson
Flying Lines
