  • July 07, 2025, 12:15:01 PM
Author Topic: mounting a clunk tank  (Read 1822 times)
Offline Sam Laughery
  • ACE
    • laurelhighlandsrc.com
« on: May 04, 2006, 09:53:47 PM »
I'm switching my Cardinal to a clunk tank for a bunch of reasons.  I've tried a number of mounting methods with mixed success.  It's a 6 Oz. Sullivan seamless.  I'm sure someone out there has come up with the perfect way to mount a clunk on a profile.  Let's see what you've got.
Thanks in advance. #^ #^ #^ #^
Sam
Offline Mike Haverly
Re: mounting a clunk tank
« Reply #1 on: May 04, 2006, 10:40:24 PM »
Here's how I do it on a profile.  This is my profile Oriental.  In this case I used a piece of CF laminate that was laying around.  Plywood works as well.  Just make a mount to fasten the clunk tank too and notch it so the tie wraps won't slip.  I used brass inserts in the fuse and slotted the mount to make it adjustable.
Online Paul Taylor
« Reply #2 on: May 05, 2006, 06:39:11 AM »
Here is one idea I stole from someone. Works well and is adjustable.
  • ACE
« Reply #3 on: May 05, 2006, 04:05:16 PM »
Thanks guys.  I went with the laminate since I had a few small pieces and it worked out great.  I'm going to try and get in a bunch of flights tomorrow and I'll let you know how I make out.
Sam
