  • June 25, 2025, 07:16:32 AM
Author Topic: More web BS test  (Read 3326 times)
Offline RC Storick
More web BS test
« on: June 27, 2017, 09:21:45 PM »
If you have received a notice this site is not secure it's because I was asleep at the switch and let the SSL certificate expire. I just renewed it and it will be an hour or so to update.
« Last Edit: June 29, 2017, 04:16:27 PM by RC Storick »
Re: More web BS
« Reply #1 on: June 27, 2017, 09:48:55 PM »
  I haven't had any problems with the site, but have noticed that the home page "stack" of the various sections is different on my computers now, with the Open Forum right on top now. Had me puzzled for a while, thinking I wasn't logged in properly or something. They are all there, just in a different order now.
   type at you later,
Offline Larry Fernandez
Re: More web BS
« Reply #2 on: June 27, 2017, 11:11:03 PM »
Thanks for the heads up
Larry, Buttafucco Stunt Team
Offline RC Storick
Re: More web BS
« Reply #3 on: June 28, 2017, 07:46:02 AM »
   type at you later,
I changed the forum stack order to make it easier to access. SSL is now installed and site is secure
Offline JoeJust
Re: More web BS
« Reply #4 on: June 28, 2017, 09:32:20 AM »
I now have to manually log in.
Joe
I only enter contests so somebody else is not always in last place
Re: More web BS
« Reply #5 on: June 28, 2017, 12:21:54 PM »
Thanks for letting us know.  I thought my computer went hay wire.   LL~ LL~
Re: More web BS
« Reply #6 on: June 28, 2017, 09:37:58 PM »
   Actually, I think you still have a problem somewhere, because using the "modify" form still triggers a warning about a "non-secure site".
Offline RC Storick
Re: More web BS
« Reply #7 on: June 28, 2017, 09:39:18 PM »
I know where the issue is and I am working on it
Re: More web BS
« Reply #8 on: June 28, 2017, 09:40:37 PM »
  Very good, thanks!  There is a workaround, use the "edit" function at the lower right, rather than the "modify" form in the upper right.
Offline RC Storick
Re: More web BS
« Reply #9 on: June 28, 2017, 10:03:12 PM »
Domain Name: stunthanger.com
URL Tested: https://stunthanger.com/smf
Number of items downloaded on page: 59
   Valid Certificate found.
   Certificate valid through: Jun 28 23:59:59 2018 GMT
Certificate Issuer: COMODO CA Limited
SSL Protocols Supported: SSLv3 TLSv1 TLSv1.1 TLSv1.2
   Server supports SSLv3, may be vulnerable to POODLE attack. It is suggested to disable the SSLv3 protocol.
Server certificate
   Total number of items: 59
Number of insecure items: 2
Insecure URL: http://www.stunthanger.com/images/stunthangarbanner.jpg.jpg
Found in: https://stunthanger.com/smf/
Insecure URL: http://stunthanger.com/smf/open-forum/we-are-back-up/?action=dlattach;attach=252560;image
   Secure calls made to other websites:
pagead2.googlesyndication.com is valid and secure.
   Insecure <form> call.
Found on line # 2181 in file: stunthanger.com/smf/index.html
(Note: Chrome will show a security error for any secure page with an insecure <form> call on the page)
Offline RC Storick
Re: More web BS
« Reply #10 on: June 28, 2017, 10:06:45 PM »
I am still working on things maybe tomorrow I will get it sorted out
Offline BillLee
Re: More web BS
« Reply #11 on: June 29, 2017, 07:55:28 AM »
Robert, from my own experience:
Look for those places in the code that use "http" specifically instead of either "https" or the default to whatever the user started out with. I suspect your 'Modify then Save' code has an explicit 'http' in there.
Yes, probably preaching to the choir!
For all: if you have a bookmark for stunthanger that uses 'http', change the bookmark to use 'https' and the message from the browser will go away. (Except for the few spots Sparky is looking for! :-) )
« Last Edit: June 29, 2017, 06:41:19 PM by BillLee »
Bill Lee
AMA 20018
Offline RC Storick
Re: More web BS test
« Reply #12 on: June 29, 2017, 04:16:54 PM »
testing
