Jim,
That looks Wonderful. Thanks for the usdate and the first one I have seen built. Nice to see it in the Isreali colors. Refreshing change up from the usual. My original Mustang is an incredible flyer, perhaps my favorite.
What are the spec's on your Mustang? Engine, weight, etc? I set up an LA46 last month with a .257" venturi off an LA25 and a ST NVA. Swung an APC 11.5 X 4W prop in a crackling 4-2-4 break on level flight, giving an immediate 2-cycle run in the maneuvers and dropping back to the level flight setting at the end of the maneuver. This setup felt like it didn't vary 10 RPM from the beginning of the flight to the end. All this at 2 1/2 ounces of fuel. Get that. 40 sized power on steroids with 20 sized fuel consumption. Clean up was easier, too. Try that out if you have a chance.
Pat Johnston
Airframe and Engine Design
Skunk Works
