  • July 19, 2025, 01:18:31 AM
Author Topic: Monoline  (Read 1277 times)
Offline andreas johansson
  • SWE-56998
Monoline
« on: June 08, 2007, 02:42:55 AM »
Hi
I´m curious, how does monoline work? How can you steer the aircraft with just one line?
Andreas
Nobler-O-Maniac
SWE 56998
Re: Monoline
« Reply #1 on: June 08, 2007, 03:11:48 AM »
It's magic. ;D
The one line is solid and is turned clockwise or counter clockwise for control input. Maybe someone can post a diagram of the system.
  • SWE-56998
Re: Monoline
« Reply #2 on: June 08, 2007, 03:16:25 AM »
Ok, I see. There must be a very special kind of handle then   :)
Andreas
Nobler-O-Maniac
SWE 56998
Offline Ralph Wenzel (d)
Re: Monoline
« Reply #3 on: June 08, 2007, 04:41:09 AM »
Imagine a Yankee Twist Drill, Clint. You hold the handle with one hand and push-pull a knurled knob which causes the shaft to spin in one direction or the other. At the outerend (toward the plane), there's an interlocking latch which holds the line (.014 for ½A - - .021 for a .35 stunt plane) to the drill.
In the plane, there's a worm-and-cam which translates the radial spin of the line into a fore-and-aft motion like a conventional bellcrank.
In the Speedmaster Control Units, the process is even simpler. A vertical arm is rotated fore-and-aft by the spin of the line Motion is limited by air pressure on the control surface(s).
Ralph Wenzel
AMA 495785 League City, TX
Willis Swindell
Re: Monoline
« Reply #4 on: June 08, 2007, 06:10:52 AM »
Here is a picture of a handle and torque unit might help understand . The bobbin on the handle slides up and down the twisted wire which turns the wire to the torque unit in the airplane.
Willis
