  • July 18, 2025, 09:07:40 PM
Author Topic: monokote/weight gain  (Read 1847 times)
Offline W.D. Roland
« on: August 08, 2006, 09:24:37 AM »
posted tis on oter site--posting here for more input on weight so i can decide on instaling cockpit or not.
monokote problems causing severe weight gain.
ordered monokote 7 days ago and having a sever case of bordom while wating causes me to look for things that airplanes should have.or mabey shouldnt have.
any one know what weight range this thing should be in?
its a sig chip monk
cockpit details and pilot-under 1oz
wing tip and adjustible guide-1/4oz
also added weight box
adjustable rudder
adjustable side and up/down thrust
adjustable tank
if monokote dosnt arive today the seat might get upolstry
http://www.clstunt.com/htdocs/dcforum/User_files/44d79b380ebe3720.jpg
http://www.clstunt.com/htdocs/dcforum/User_files/44d79b700f412afe.jpg
David
David Roland
51336
Offline W.D. Roland
Re: monokote/weight gain
« Reply #1 on: August 08, 2006, 09:28:51 AM »
pics didnt copy/paste so here they are.
David Roland
51336
Online Crist Rigotti
« Reply #2 on: August 08, 2006, 05:20:20 PM »
You can figure that Monokote adds 1 gram of weight to each 8.5 sq in of wing area.  Example 850 sq in = 100 grams of Monokote.
Offline W.D. Roland
« Reply #3 on: August 08, 2006, 09:26:57 PM »
thanks for replies
what im after is what is a good finished weight for sig chipmonk.
if its gettin heavy things can be lightened or left off(cockpit)as i finish it.
if im light i can smile.
my current estimate has it coming in at 42oz.
rudderless-i agree with you on monokote vs real finish
in this pic fun planes are monkote
more sreious stuff is paint
David Roland
51336
Offline Richard Grogan
« Reply #4 on: August 08, 2006, 09:58:37 PM »
Mine is 39.4 oz stock with monokote, trim paint with ultra kote paint. (original paint scheme as on box)...has wheel pants but no pilot/ cockpit, just painted interior light coat of black. Enya .35 is power. You might be real close to you target weight...
RG
Long Live the CL Crowd!
                  AMA 85745
Offline W.D. Roland
« Reply #5 on: August 09, 2006, 09:42:36 AM »
thanks for info Richard!
i see you are in houston. im in west central louisiana.have racing friends in houston and used to know c/l fliers in houston.flew contest in houston several times a year many years ago.
is Richard Stubblefield still around--i think hes from your area.I heard Buckstaff went to the great combat circle in da sky.the Wheelers were from houston?
last ama fast combat match i ever flew was in alexandria with Stub in fly off for first/second
the match was flown twice(!!?)killed him both times. still know where my broke airplanes are.rib him for me if you get a chance
i was the crazy hippie kid.
what kinda contest activity is going on in the houston area?as far as i can tell none in louisiana.I may be spending some time in houston area soon and would like to do some flying while there.
 would you consider your airplane as heavy-light or medium?
 anyone else with sig chipmonk weights and performance?
is monokote made in china now? dosnt seem to shrink as good as it used to--and i dont kote good as i used to!
thanks
David
David Roland
51336
« Reply #6 on: August 09, 2006, 07:33:15 PM »
thanks
David
HI David,
From memory, most Sig S-Cs I have heard the weights on seemed to be right around the low 40 oz. range, 39-45 generally, which ain't bad for a mass production kit that size.  The ones I've seen are good flyers.
Bill <><
