  • June 29, 2025, 06:13:01 PM
Author Topic: monokote or whatever type of film removal from covering  (Read 1946 times)
Offline Kreth
« on: February 04, 2016, 09:13:57 AM »
I have a plane that someone gave me that has an AMA # on the wing that I want to remove.  I have used every type of solvent that I could think of and nothing will seep under the edge where they can be removed.
HELP !!!!!!!!!!!!!!!!!
Kreth McKee AMA 22004
Re: monokote or whatever type of film removal from covering
« Reply #1 on: February 04, 2016, 10:08:56 AM »
did you try heat?
aside from that I would try to flood some acetone along the edges and let it work at the adhesive
Online John Rist
« Reply #2 on: February 04, 2016, 11:05:56 AM »
Use a heat gun to remove letters. Use Top Flite MonoKote Trim Solvent to remove the left over adhesive that is left behind.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZ43&P=7
Offline Kreth
« Reply #3 on: February 04, 2016, 11:07:55 AM »
Tried heat, acetone, lacquer thinner, MEK, methylene chloride, and paint remover.  No luck!!
« Reply #4 on: February 04, 2016, 11:20:41 AM »
Heavy hand with coarse sandpaper or an EX-Acto knife.    LL~ LL~ LL~
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: February 04, 2016, 11:50:20 AM »
Like John Rist said, the trim solvent works to clean it up.... But also, if you "flood" the edges a little with trim solvent it will wash away the adhesive on the ends and get at least a corner to raise. Then keep wiping at it, under the lifted corner with a paper towel wet with trim solvent. You'll slowly wash away enough adhesive to lift it away. I've found the trim solvent works best for removing really stuck on layers. You might even have to pull up the raised corner with tweezers to keep wiping. It certainly can be tedious. Especially if the last guy did a great job... Lol
Offline Paul Wood
« Reply #6 on: February 05, 2016, 09:48:45 AM »
I've had good luck using xylene to melt Monokote adhesive. I've used it to apply Monokote trim pieces and to seam Monokote to itself. I've never tried it on any of the other covering brands.
« Reply #7 on: February 05, 2016, 12:21:04 PM »
Hard to believe heat won't work. Have you tried slipping a single edge razor blade under a corner and then pulling while heating? Are you sure they film and not paint?
Offline dirty dan
« Reply #8 on: February 05, 2016, 03:57:25 PM »
If it's Monokote over Monokote, if upper layer of film was applied with trim solvent, if the job was properly accomplished, I'm thinking it ain't never coming off base layer of film. Sorry...
Dan
Dan Rutherford
Offline Kreth
« Reply #9 on: February 07, 2016, 06:02:25 PM »
Thanks for all the ideas.  I had probably tried them already.  I think that how long the trim has been on has a lot to do with it.  I was able to get off what I needed to with the scraping with a single edge and then using acetone to get off the adhesive color.  I had tried this in the beginning and had scraped the solid color (black) monocote and was looking for an easier way.
« Reply #10 on: February 07, 2016, 06:06:42 PM »
Kreth,
There's stuff we use in the professional sign and graphics trade.
PM me your address and I'll get some out to you.
Should be able to put it in the mail. I hope.
Charles
