  • July 19, 2025, 09:25:27 PM
Author Topic: Model ID  (Read 1565 times)
Offline Jim Mynes
  • Chelsea, ME
Model ID
« on: June 22, 2018, 04:12:04 PM »
Does anyone recognize this model? It was given to me by a guy who is getting rid of all his stuff. He couldn’t recall the name of it.
It has a sand cast ST51 in the nose.
Wingspan is 58”
Length is 42”
I have seen the light, and it’s powered by a lipo.
Re: Model ID
« Reply #1 on: June 22, 2018, 04:41:03 PM »
Looks like a Buccaneer 746 to me. Good flying plane, designed by the late Allen Brickhaus. I'd expect the engine is a ST G.51? That's a very good engine and excellent match to the 746.  D>K Steve
Re: Model ID
« Reply #2 on: June 22, 2018, 05:30:04 PM »
Yeah, definitely a Buccaneer 746.
Offline Jim Mynes
  • Chelsea, ME
Re: Model ID
« Reply #3 on: June 22, 2018, 06:22:11 PM »
Thanks, guys. Buccaneer makes sense, as he also contributed a Savoy, also an Allen Brickhaus design if I’m not mistaken. Perhaps he was a fan of Allen’s designs.
Offline Jim Mynes
  • Chelsea, ME
Re: Model ID
« Reply #4 on: June 22, 2018, 06:34:11 PM »
Yes there’s a big G on the non-exhaust side of the engine.
I remember reading about Italian vs. Chinese Super Tigres on here recently. I’m afraid I’m not familiar enough with them to know the difference.
His stuff has been sitting around for a while. The wheels are flat-spotted. So I’m thinking this might be an older, Italian ST.
Re: Model ID
« Reply #5 on: June 23, 2018, 09:05:26 PM »
Chinese ST have 4 digit No stamped on mounting lug edge . ( Wheter it says made in Italy on NOT . usually CHINA inside backplate .Itl Components Ass in China have the stamed lug ) My preferance is Italian , tho Ive one Chinese . Shaveing the bar over the bypass ( And Maybe the ' G ' , )
makes screwdriver access far better .
A Top flite wood 12 x 5 will work good , and BETTER cut to 11 5/8 in.  as youll get ' The Break ' good with that . If you cant find any 10 x 6 3 Bl Tornado's .
Should have 3/4 turn full 4 stroke to clean two stroke , Warm Up , needle in to full 2 , back out maybe 1/4 , to the brrrp brrrp bit , Itll be near correct .
Tend to run muffler pressure .
the ten ton Silent Mudffler works well . No power loss . Will haul a ten ton plane , load gets ' the break ' working A1+ in my opinion .
a 4 or a 6 inch pitch , is not a good idea , in my experiance . Tho theyll waffle along quitely on a 12 x 6 , itll take a bit to get ' the break '.
First Few gallons 23 % oil . 18 % 50/50 after , unless your in boiling weather . Dosnt really need nitro . tho 5 % is plenty .May run better without it .
 H^^
Re: Model ID
« Reply #6 on: June 25, 2018, 02:13:08 PM »
The late Tom Lay said the Chinese G.51 was usually as good as the Italian ones, but perhaps the bearings. The ring was always replaced with a Bowman ring. There were two cylinders available, the R/C and CL ones. The CL one had milder timing and yet a lot of people preferred the R/C version. Brian Gardner has made at least one batch on ABC piston/cyl., and an optional head, but I have not read anything posted here by users of the G.51 with Brian's conversion. I've bet $ that it'll work very nicely.   y1 Steve
