  • June 17, 2024, 06:28:24 AM
Author Topic: Wood Props?  (Read 1964 times)
Offline Mike Callas
Wood Props?
« on: March 12, 2017, 01:16:27 PM »
Re: Wood Props?
« Reply #1 on: March 12, 2017, 01:56:34 PM »
The story that really fascinated...or disgusted...me was about the P-39's prop. The thing was always unimpressive, until after WWII was over, when somebody bolted a P-51 prop on it and totally changed the performance from mediocre to awesome. We'd think that even engineers would be savvy enough to try an assortment of different propellers on their new plane, right? Apparently not. S?P Steve
Offline Terrence Durrill
Re: Wood Props?
« Reply #2 on: March 12, 2017, 06:08:12 PM »
            Wow...a lot American Pilots died in P-39's because of poor performance as compared to the Japanese fighters.  We sure could have used high performance P-39's in WWII, but unfortunately, it is a little too late now to worry about that.     D>K      H^^
Offline Astropuppy
Re: Wood Props?
« Reply #3 on: March 12, 2017, 09:35:37 PM »
Astropuppy
Offline John Rist
Re: Wood Props?
« Reply #4 on: March 12, 2017, 09:44:08 PM »
I am sure that a lot of improvements could have been made however it was all out war and production of war material was at max capacity.  There was no time for improvements.  I am sure someone was aware that a better prop would be wonderful but they just weren't available!  PS what a great story  H^^
Offline Tony Drago
Re: Wood Props?
« Reply #5 on: March 12, 2017, 10:13:06 PM »
Fantastic short movie. Thank you.
 On the P-39 you can thank those penny crunching bean counters back then. The P-39 was a very good fighter if it was set up right. It was never given the chance it deserved to prove it self. A lot of pilots were worried due to the engine location. The pilots feared the engine would crush them on a bad landing. Also the thought of the prop drive shaft running right underneath the pilot
 In the history of the P-39 not one engine mount failure to cause hurt the pilot. The plane had a better center of gravity and handled very well.
 But as mentioned above, to little to late.  Also a Steve mentioned. the prop was one fix. The engineers knew what the plane was capable of. It was  the freaking Gov't bean counters that should take the blame for holding back the 39's performance not Bell Aircraft.
Offline Air Ministry .
Re: Wood Props?
« Reply #6 on: March 12, 2017, 10:23:02 PM »
" In Russia we dont let pilots over 40 fly the Airacobra !."
Yeager , " Why " .
Russian ," Their balls get caught in the propshaft . "
Seems the Cold Climate suited them . Use machineguns to check sights , Then use the cannon .
Offline Gary Dowler
Re: Wood Props?
« Reply #7 on: June 13, 2017, 03:52:59 AM »
Yeager said in his book that he would not have hesitated to fly the P-39 in Europe.  That's pretty good testimony in my estimation.
Offline Perry Rose
Re: Wood Props?
« Reply #8 on: June 13, 2017, 10:25:03 AM »
The P-39 was better suited to low level ground attack with the cannon and bombs. The Russian front air battles were mostly low level and the cannon was good on tanks. The western front was mostly high level where the P-39 wasn't suited. The Russians didn't baby the engines to get the best performance out of it and to be a match for the Germans. There wasn't enough room for a bigger supercharger and the Russians them badly.
