  • August 05, 2025, 02:07:54 AM
Author Topic: .077" sheet balsa  (Read 2848 times)
Offline dale gleason
.077" sheet balsa
« on: January 08, 2017, 02:20:25 PM »
Is there a supplier of .077" balsa sheet these days? 3" or 4" x 36" ?
dale g
Re: .077" sheet balsa
« Reply #1 on: January 08, 2017, 06:14:23 PM »
dale g
Hi Dale,
I used to get it from Riley.  It was a special order!  I think they just ran 3/32 through the sander again.  I don't know of any specific sources today.  I would also like to find one!
« Reply #2 on: January 08, 2017, 06:27:12 PM »
You Cold always try Two Milimeter sheet !
2mm = 0.07874
Offline BillLee
« Reply #3 on: January 08, 2017, 06:39:44 PM »
dale g
Dale, I have a bunch of .077" sheets, but unfortunately they are still in the middle of some 2" blocks, and will be awful hard to get out!  ;D <= n~
Bill Lee
AMA 20018
Offline BYU
« Reply #4 on: January 08, 2017, 08:53:07 PM »
I have 4 cases of 3 inch 77 thou roughly 2,000 sheets
how much do you need?
« Reply #5 on: January 08, 2017, 09:08:51 PM »
PM sent, Thank you Uncle Bob.
dale g
« Reply #6 on: January 08, 2017, 09:58:55 PM »
blank
« Last Edit: March 06, 2022, 04:36:17 PM by Motorman »
Offline BillLee
« Reply #7 on: January 09, 2017, 06:54:29 AM »
What do you use it for, ribs on bigger wings or maybe really light fuselage sides?
So they can sand it to 1/16" instead of just using 1/16" to start with!   #^ n~ LL~
(Sorry, Dale, I just HAVE to stick you with a stick every once in awhile!  ;) )
Bill Lee
AMA 20018
Offline Crist Rigotti
« Reply #8 on: January 09, 2017, 07:58:24 AM »
Dale,
Check your PM.
« Reply #9 on: January 09, 2017, 09:49:44 AM »
"My balsa is too thick!"
"My balsa is too thin!"
"My balsa is juuusssst right!"
It is for Wrap-molding fuselages and leading edges wetted down. Strong enough yet doesn't leave you with a horse to feed.
dg
« Reply #10 on: January 09, 2017, 10:58:45 AM »
I guess with the passing of the Dad of the son who now runs the shop in Irving doesn't cut balsa any more or is just doing it for the free flight guys that know him.  Was surprised to learn that the shop is a historic landmark when I visited last year.
Now it comes to me after I posted.  MAL( Model Airplane Labs)  in Irving Texas.  When I first met the Dad many, many years ago he bragged about cutting balsa for the late and great Bob Gieseke.
Offline Kim Doherty
« Reply #11 on: January 10, 2017, 03:53:10 PM »
dale g
By far the best way to bring your materials to the optimum thickness: Byrnes - Model Machines Thickness Sander. Just a beautifully built tool.
http://www.byrnesmodelmachines.com
Kim.
Offline Chuck_Smith
« Reply #12 on: January 10, 2017, 04:37:10 PM »
Riley was the best.
You could ask him for 4-6# C grain, 8# A grain, whatever, and that's what you got - at a very reasonable price. I've still got some big blocks for fuselage tops he sold me.
AMA 76478
Offline Bill Johnson
« Reply #13 on: January 11, 2017, 01:46:31 PM »
Kim.
That's much more reasonable then I would have thought. $350 whereas I was sure it would be $1K at least, just looking at it.
Best Regards,
AMA 350715
« Reply #14 on: January 12, 2017, 09:47:45 AM »
How long would it take to make the investment back if a person started doing custom thickness sanding for people?   I have a wood workers hardwood planer that I have used to get boards the same thickness.
