  • July 28, 2025, 04:17:49 AM
Author Topic: Minature clevis for Nobler  (Read 1319 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: December 28, 2006, 05:03:07 AM »
Not enough room in the rear of an ARF Nobler for a full size UHP clevis so I made a miniature version. This actually started life as some sort of steel RC clevis I picked up in my travels. It had a 4-40 screw all the way through the fork, not sure what it was used for. I inserted a 4-40 screw, brazed it in place then cut it off to give me a solid fork.
Used a 1/16 pin and 2-56 screw. Only problem is the pin and screw are so small they will be easy to loose. Think I will epoxy a small magnet in the rear of the Nobler to catch the parts when I drop the little buggers. All this because I only wanted an access hatch on one side, I would have used a Sullivan Gold but would have needed to get access to both side to adjust it. Is this silly or what....  ;D
Offline Keith Spriggs
    • khspriggs
Re: Minature clevis for Nobler
« Reply #1 on: December 28, 2006, 11:53:07 PM »
Very nice work, Bob and also creative.
Offline Richard Grogan
« Reply #2 on: December 29, 2006, 01:05:23 AM »
That looks pretty durable for that little narrow gap! Good job!
Long Live the CL Crowd!
                  AMA 85745
Offline Wayne J. Buran
« Reply #3 on: December 29, 2006, 04:52:13 AM »
That clevis is made by "Ultra Hobbies" and was available and still may be available thru Central Hobbies. There was a button head screw (4-40) that held a stepped 3/32 pin in the clevis. Nice units but usually to large for C/L use. I have a couple left in stock.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline Bootlegger
« Reply #4 on: December 31, 2006, 06:59:32 PM »
 Looks  a lot like a BU-BRO clevis it too has a 4-40 screw thru it . I have used them for a number of years. It is also threaded 4-40 on the long end so it can be screwed onto a 4-40 bolt.
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
« Reply #5 on: January 01, 2007, 12:05:55 PM »
That is exactly what it started life as... Couldn't remember..
Can't imagine what they would be used for in stock form, the 4-40 screw is threaded all the way through and who would use screw threads for any kind of a bearing surface.
I would start manfacturing the small clevis but it took me 4 hours to make one.
