Hi All:
I have been using 60' lines for most of my Sport Flying on all of my planes. I use 52' on my .15 size planes and am happy with the results. However, something the other day made me rethink what length of line to use on different airplanes. One size may not fit all!
I was flying a third hand Super Clown that the previous owner could not get it to maneuver. It could not even do a very large loop! This plane is powered by a Brodak .25.
I got the plane from the owner after he crashed it, repaired it and added some tail weight! I had about twice as much tail weight that I needed so I removed half of the weight and no the plane flew, but not well. A friend of mine who was watching this spectable suggested that I try shorter lines. I just happened to have a new set of FAI lines with me so I tried a flight with them. WOW! what a difference! The plane no acts like a stunter. It stays out on the lines, does not flop around in maneuvers and responds very well to control input. It grooves!
Now the big question! Does each plane/engine combination require a certain length of lines to extract the maximum performance? I always used 52'and 60' but I may be missing some tuning advantage.
Have you other fliers found that different length of lines for different planes make a difference?
I have a large stash of .09-.15 planes hanging in my attic that may require 35-45 foot lengths.
Any suggestions regarding line lengths for various sized planes?
Tia,
Frank
