  • July 07, 2025, 04:02:35 AM
Author Topic: Winter storage.  (Read 2256 times)
Offline kevin king
Winter storage.
« on: November 05, 2021, 12:44:15 PM »
When storing airplanes for the winter, I like to fill the tank with fuel. My question is do i need to disconnect and cap the fuel line that goes to the engine? Or just leave it attached to the motor? I dont want any fuel dripping out of the venturi on to the plane below.
Thanks.
Kevin.
Re: Winter storage.
« Reply #1 on: November 05, 2021, 01:22:29 PM »
Kevin,
One problem with not capping the fuel feed is even though the vents are capped it can still drip from the NVA and will either fall on the ship below or floor which can cause dull spot on the finish. I am lazy and just put the ship on the rack and before flying in the spring just flush with old fuel and go fly a couple safe flights to clean things out.
Best,    DennisT
Re: Winter storage.
« Reply #2 on: November 05, 2021, 02:21:43 PM »
I just (sometimes) cap the tank vents to keep dust out.  The inside is already well oiled from fuel.  In fact the nitro and alcohol will likely do more damage than good.  Dub Jett made it a big point to me to run the engines completely dry from fuel-then you could oil if you want to, the raw fuel can promote corrosion.  I use air tool oil for storage.  It's meant to displace moisture. The tanks, leave dry.  I have some pretty old tanks around that are in good shape as long as I didn't use brass tubing in them nor any form of acid flux to solder them.
Offline Mark wood
Re: Winter storage.
« Reply #3 on: November 05, 2021, 02:47:06 PM »
There are two other problems with leaving the tank vented. Evaporation although slow is still present changing the fuel blend. And worse moisture in the air. Alcohol really, really likes water and visa versa. Fortunately though the humidity in a heated room is lower than normal but your fuel in the tanks unvented will collect moisture making the fuel not very good.
Life is good AMA 1488
Re: Winter storage.
« Reply #4 on: November 05, 2021, 03:00:46 PM »
   Fill  tanks with Coleman Lantern Fuel and then completely cap off all vents and tubes. It's relatively cheap, easy to find, not prone to evaporation, and when you drain it, what's left in the tank will mix well with glow fuel and run out on the first flights of the year.
Offline Peter in Fairfax, VA
Re: Winter storage.
« Reply #5 on: November 06, 2021, 06:46:52 AM »
I'd go with denatured alcohol (one type of stove fuel.)  Inexpensive.  Would not go with glow fuel.  Castor residue doesn't sound good, nor does nitro.
Offline Dave Harmon
Re: Winter storage.
« Reply #6 on: November 06, 2021, 08:31:19 AM »
My airplanes have removeable tanks so during the off season I have been flushing the tanks with lacquer thinner then capping off and put in a box until the weather gets better.
I partially fill the tank then cap it and slosh around to get some agitation going then blow out with a syringe then cap off.
At the start of the next season I have been sloshing again then draining slowly on a paper towel looking for any chunks then re-installing in the airplane.
So far....I have not had any problems do it it this way.
Hopefully the thinner is not causing any problems with the integrity of the tin....can't have any rust dont'cha know!
As far as engines over the winter....I have been using Castrol 00-10 full synthetic oil for years and the engines are always spiffy when they come out of hibernation. They always start right up because that Castrol is much like the oil we use in fuel...never gets gummy and is available at Walmart but best of all.......it don't stink!!
Offline John Rist
Re: Winter storage.
« Reply #7 on: November 08, 2021, 10:13:16 PM »
I drain all of the electrons out of my motors and put the fuel containers in a vented amo can.   LL~
Offline Perry Rose
Re: Winter storage.
« Reply #8 on: November 09, 2021, 05:47:14 AM »
I fly all winter.
Offline Doug Moisuk
Re: Winter storage.
« Reply #9 on: November 09, 2021, 09:40:30 AM »
Paul G put me onto Turbine Oil. I use to use klotz oil but it’s too thick. Hard to force into the tank and remove. I reuse the turbine oil as it’s pricy. Cap the tank when full of the oil flush with alcohol and then fuel in the spring.
I use air tool oil in the engine.
Doug Moisuk
MAAC 3360L
Offline Doug Moon
Re: Winter storage.
« Reply #10 on: November 10, 2021, 07:23:32 AM »
Hello Kevin,
Not to totally change the subject, but, how did you paint the wave on your Tsunami?
Thank you
Doug
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline kevin king
Re: Winter storage.
« Reply #11 on: November 10, 2021, 01:12:52 PM »
Hi Doug. Ive done a few waves, 1 on a 60 size ship, and 2 on 1/2a size planes.  The best way was to follow Windy's video step by step. Painting of the wave starts half way into the video. I also have a lot of computer generated mask files for anyone that wants them.
Kevin King
Online ray copeland
Re: Winter storage.
« Reply #12 on: November 10, 2021, 04:14:45 PM »
Would love a link or part number for the Castrol 00-10 full synthetic oil  at walmart,  #^
Offline kevin king
Re: Winter storage.
« Reply #13 on: November 10, 2021, 11:58:07 PM »
Thank you for all the replies gentlemen. Looking forward to next years season.
Kevin.
Offline Dave Harmon
Re: Winter storage.
« Reply #14 on: November 11, 2021, 12:27:40 AM »
I don't have a p/n but it is on the shelf in the Automotive area....00-20 is ok too.....and a lot easier to find.
A lot of it shows up on the Walmart website.
Offline Doug Moon
Re: Winter storage.
« Reply #15 on: November 12, 2021, 08:26:10 AM »
Watching that Windy Video brings back so many memories!  Thank you so much for the link!
Doug Moon
AMA 496454
Re: Winter storage.
« Reply #16 on: November 12, 2021, 02:48:50 PM »
   Kevin has been pretty busy establishing a Windy video channel on YouTube. The club I belong to inherited a large collection of tapes that is just under 50% of everything Windy recorded. We have 13 more file storage boxes of tapes to convert, edit and up load yet and combined with some other videos that Kevin has acquired, we should be close to a complete collection. We have come to a small bump in the road getting the remaining videos converted but we are working on that. Definitely a long term project but very doable.
