  • July 14, 2025, 12:31:49 AM
Author Topic: Need a little help with Youth's Tutor. Part needed.  (Read 759 times)
« on: July 11, 2010, 01:51:07 PM »
I am ready to start putting the hardware on to get this plane ready. Tyler, the youth who will get this plane stopped by last night to check on the progress.
Arlan donated the plane, and sold a LA 40 at a good price to Tyler's dad. (Eric) It needed a ventrui and a NVA. The engine was drilled out for a ST NVA so I needed another ST NVA to go back in. Zuriel donated a ST NVA. Problem is the NVA is a 60 size. Will not fit. I hate to drill the case out larger. Here is where the help comes in.
I need to swap a NEW (Back in the package) ST .60 size NVA for a .40 size.
Can anyone help out please?
You can PM me or send me a email. flybywires at yahoo dot com
Offline Garf
    • Hangar Flying
Re: Need a little help with Youth's Tutor. Part needed.
« Reply #1 on: July 11, 2010, 02:14:28 PM »
All the ST units are the same diameter. You need an OS or Enya unit.
« Reply #2 on: July 11, 2010, 05:18:24 PM »
Thanks Phil. That is what Zuriel said but it seemed a little tight. I will try it again.
« Reply #3 on: July 11, 2010, 05:43:28 PM »
Stuff tissue, with some light oil oil on it to wet it, into the crankcase hole and take a round jeweler's file to it.  If it is a *little* tight.  If it will actually go in the hole already, then you don't need to do anything. (it seemed a little tight ??)
Mongo
« Reply #4 on: July 11, 2010, 07:46:38 PM »
Took a #11 exato blade and cleaned the hole. Got it in.
Thanks guys!
