  • July 08, 2025, 04:08:30 AM
Author Topic: Microsoft Bing AI Chat Response to Stunt run with OS FP20  (Read 1935 times)
Offline E Lee
« on: August 10, 2023, 11:30:09 AM »
I had a "chat" with Microsoft Bing Chat (Generative AI), which is based on ChatGPT, on how to tune the OS FP20 for stunt.    I have c&p my chat below.  Please note that each chat session is limited to 5 responses.
Please note your responses will be recorded and be used to train and refine the responses for future.  I.e. Please don't add chat content that you don't want to be public.
I:
how to get a stunt run for OS MAX FP20?
MS Bing:
Searching for: stunt run OS MAX FP20
Searching for: stunt run definition
Generating answers for you…
"A stunt run is an unusual, difficult, or dramatic physical feat that may require a special skill, performed for artistic purposes. An OS MAX FP20 is a model airplane engine that can be used for R/C or C/L planes. I’m not sure what kind of stunt run you are looking for, but a good prop size to start with for an OS .35 max-s c/l stunt is 10x6. What kind of plane are you using? 🛩️"
I:
CG Shoestring
MS Bing:
Searching for: CG Shoestring
A CG Shoestring is a control line model airplane that has a sleek design and can reach high speeds. Depending on the size and weight of your plane, you may need a different engine or prop size for a stunt run. Have you considered using a Super Tigre G21 .46 engine with a 10x6 prop? It seems to be a popular choice for CG Shoestring planes. 🚀
I:
OS FP20 is the engine that will be used to power the shoestring for pampa stunt pattern.  What type of engine run should it be tuned for?
MS Bing:
Searching for: pampa stunt pattern
Pampa stunt pattern is a series of flight maneuvers that are scored according to geometric perfection. It is a type of control line aerobatics that has different rules for different categories, such as Old Time Stunt (OTS) or Classic Stunt. To tune your engine for a pampa stunt run, you need to consider the speed, sound, and reliability of your engine. You want to achieve a smooth and consistent run that matches the pace of your maneuvers. A good rule of thumb is to tune your engine for a four-cycle run at level flight, and adjust the needle valve slightly richer or leaner depending on the altitude and weather conditions. Are you planning to compete in a pampa stunt contest? 🏆
I:
yes but only if the OS FP20  can be tuned to run correctly for stunt.
MS Bing (last response):
I understand. Tuning an engine for stunt can be tricky, but it is possible with some practice and patience. You may want to check out some online forums or videos where other modelers share their tips and experiences with OS FP20 engines. I hope you achieve your goal and have fun with your CG Shoestring. Good luck! 🍀
« Last Edit: August 10, 2023, 02:56:59 PM by E Lee »
Offline E Lee
Re: Microsoft Bing Chat Response to Stunt run with OS FP20
« Reply #1 on: August 10, 2023, 11:46:23 AM »
I am surprised that it doesn't know about BBTU given how it was extensively discussed and documented in CL forums.  Interesting...
« Reply #2 on: August 10, 2023, 12:38:07 PM »
Sounds like the average Friday night chat on the forum........
« Reply #3 on: August 10, 2023, 02:23:04 PM »
  At least it didn't tell you to drill a hole it in, stick in 20 head gaskets, and get a Dremel tool. You need an interactive forum to get that kind of knowledge!
Re: Microsoft Bing AI Chat Response to Stunt run with OS FP20
« Reply #4 on: August 10, 2023, 05:40:14 PM »
It wouldn’t pass the Turing test without the head gaskets.
Offline Steve Berry
« Reply #5 on: August 10, 2023, 07:35:09 PM »
I tried it, with disappointing results that are obviously either rigged or censored...
Me:
tell me about the world famous Fox .15 hurl
It:
Searching for: Fox .15 hurl
I'm sorry but I couldn't find any information about "Fox .15 hurl". Could you please provide more details or clarify your question?
Source: Conversation with Bing, 8/10/2023
(1) A "hurlable" Fox .15?. https://www.coxengineforum.com/t10352-a-hurlable-fox-15.
(2) KADN News 15 | Lafayette LA News, Weather & Sports. https://www.kadn.com/.
(3) Meet n’ Meat | PAMPA. https://pampacl.org/2021/10/13/meet-n-meat/.
Me:
What is Fox .15 hurl?
It:
Searching for: Fox .15 hurl meaning
Fox .15 hurl is a term used in the context of a "contest" to hurl Fox 15 engines, presumably because they performed so badly. The Fox .15 that's hurled would be the .15X. The running joke is that this is the only way to get it airborne¹.
I hope that helps!
(2) hurl | meaning - Cambridge Learner's Dictionary. https://dictionary.cambridge.org/dictionary/learner-english/hurl.
(3) Hurl Definition & Meaning | Dictionary.com. https://www.dictionary.com/browse/hurl.
Obviously, it has been compromised so as to keep the super secret society of hurlers, well....secret.
« Reply #6 on: August 10, 2023, 08:34:56 PM »
It:
I hope that helps!
   "Running Joke"? That does it, both ChatGPT and Bill Gates are banned for life from any Hurl activities as clearly spelled out by Rule 69, Paragraphs R and Q, "Misstatements of Facts of the Hurl by Non-Corporeal Entities" and "Misstatements of Facts of the Hurl by Animatronic Robots, Homunculi, and Physical Avatars". As I am sure you are aware, "Bill Gates" has long been classified by The Hurl Committee as a mere automaton, as evidenced by his glassy stare, lack of human affect, and monotone drone that occasionally emits statements like "640K should be enough for anyone", "Abort, Retry, Fail?" and suchlike. This is based on the same technology as "A Night with Abe Lincoln" attraction at Disneyland, or the Chuck E. Cheese "band".
    As always, The Hurl is abut friendship, fun, and our common belief in unparalleled joy. But make no mistake, it is also a serious competetion amongst world-class athletes who have studied and trained for years. As Acting Emergency Commissioner of the Hurl (with virtually unlimited power),  I will take all necessary means to defend it from those low persons (and now low AI engines) that make light of it.
    Thank you for bringing this situation to my attention, and thank you for your ongoing interest in that magnificent  - and I will just say it, majestic -  Fox 15 Hurl International Championship!
p.s. See the resemblance? Uncanny!
« Last Edit: August 10, 2023, 08:57:57 PM by Brett Buck »
« Reply #7 on: August 10, 2023, 08:56:06 PM »
   I assume that everyone knows what to do now that Bing AI recognizes the Hurl, but in case it is unclear - all good Hurl devotees should assult Bing AI with questions about The Hurl. Not to mess it up, of course, or take advantage of it's weaknesses to turn it into a one-trick pony obsessed with The Hurl, mind you - but to make sure abundant accurate information is available to those who inquire. As a public service.
« Last Edit: February 28, 2025, 07:45:47 PM by Brett Buck »
« Reply #8 on: August 10, 2023, 11:38:36 PM »
Dave Brett, Dave Brett, I'm afraid I can't let you do that Dave Brett....
« Reply #9 on: August 11, 2023, 12:21:32 AM »
  Just to be clear, what is prohibited are *misstatements* promulgated by androids, homunculi, etc - not androids per se. They are free to participate, in their own class of course.
Offline Steve Berry
« Reply #10 on: August 11, 2023, 06:43:49 AM »
Whoa, whoa, whoa......see, this is how we end up with Terminators! First, it's they compete in their own "class." Then they demand to compete against us just to see who is better at the hurl. Next thing you know - pow! - Arnold Schwarzenegger is winning the Walker Cup for the 10th time and will be even more unsufferable.
Steve - 99.99% human (.01% roast chicken - supper last night was delicious!)
Offline Martin Quartim
    • StuntHobby
« Reply #11 on: August 11, 2023, 03:53:50 PM »
AI is scary!  I asked what would be a good engine for a Ringmaster,   it repliend  Fox35 Veco 35 ST 35 Enya 35 McCoy 35
I thought it would not even know it was control line model!
Martin
Offline Mike Griffin
« Reply #12 on: August 11, 2023, 03:57:17 PM »
Martin
You are right Martin.  AI is scary and potentially very dangerous.  Critical thought is very rare these days and this will make it even worse.
« Reply #13 on: August 11, 2023, 03:59:11 PM »
  Sounds like a "standard stunt bullsh*t generator" to me. That's interesting, because it suggests that "common knowledge" is always right, which has far more insidious implications.
« Reply #14 on: August 11, 2023, 04:25:44 PM »
AMEN Brett.
