General control line discussion => Open Forum => Topic started by: Paul Wood on August 18, 2018, 03:31:27 PM
Title: Meet "Gracie Rose"
Post by: Paul Wood on August 18, 2018, 03:31:27 PM
Sounds like the name of a boat doesn't it? But it's my new plane, named after the middle names of my two granddaughters. I have a Continental that I love, but I decided to build another one  with a few mods. So it's a Continental wing and vertical, but the horizontal is 5% larger. The fuselage is my own design and the engine is a side mounted LA .46. I tried a few new construction methods I've been thinking about, and they went well. Here's the details:
1. Built-up flaps and horizontal tail (see photo)
2. Box fuselage with blue foam top and bottom. Foam is covered with 3 layers of 3/4 oz glass cloth using MinnWax Polycrylic
3. Clear UltraCote wing covering ruffed with 400 grit paper before primer
4. Side mounted engine with R/C firewall mount
5. Fiberglass cowl using lost foam method
6. All wood sealed with 1 coat of Polycrylic. Then I used my fingers to apply two coats of "slightly" thinned Elmer's wood putty to all wood surfaces. Sanded between coats with 320 grit. Sanded super easy and then another coat of Polycrylic before DupliColor primer. Minimum primer required. Actually just enough to stabilize color coat.
7. DupliColor lacquer, water-slide decals, and 2K Spraymaxx clear.
8. Weighs 46 ozs.
Waiting for cooler weather here in NE Texas before I give it a spin.
Title: Re: Meet "Gracie Rose"
Post by: Trostle on August 18, 2018, 03:39:34 PM
So, how much does it weigh?
Post by: Jim Hoffman on August 18, 2018, 03:48:51 PM
Item 8 on his list says it weighs 46 oz.
I'd like to know how he's going to get the tire marks out of the white table cloth.
Nice airplane, wishing it a long and successful life.
Post by: M Spencer on August 18, 2018, 08:12:15 PM
Looks very nice .
Im inclined to notch the muffler bolts at the joint face , or a bit down . With the side mount set up . Just in case the earth moves .
Like tyhe symetry in the ( some ) pictures .
Post by: Mike Griffin on August 18, 2018, 08:25:57 PM
Very nice.  What was the finish color...Dope, spray paint etc?
Post by: Roy DeCamara on August 18, 2018, 11:03:04 PM
Item #7 Mike.  Do you guys take time to read the posts???   S?P S?P S?P
Post by: Vincent Judd on August 19, 2018, 12:48:40 PM
Beautiful job, well done.
So instead of molding top and bottom blocks, you just carved/sanded the blue foam and then covered it with glass.  Interesting.
Different combination of finishing methods, looks like all went well.
Kind of has a Max Bee look to it, I like it.
Two thumbs up.
Vince
Post by: john e. holliday on August 19, 2018, 03:39:11 PM
I like it.  Nice color scheme.  Hope you get many flights with it. H^^
Post by: mike londke on August 19, 2018, 04:09:02 PM
I gotta ask, why the R/C carb?
Post by: Ted Fancher on August 19, 2018, 05:46:15 PM
Mike,
Just in case the two wire thing don't work out!  Never hurts to plan ahead ya know! y1 y1 S?P
Ted
Paul,
Gotta tell you.  I love the way you've laid in a good looking red wing within the white.  Overpowers the white and gives the illusion of the ship having a wing more appropriate to the size of the rest of it...their oversized wings being one of the few things about the vast majority of stunt ships I've never grown to love. y1 y1 #^
Ted
Post by: Randy Ryan on August 19, 2018, 05:47:46 PM
Looks great and I LOVE that wide track!!!
Post by: Mike Griffin on August 19, 2018, 05:57:13 PM
Roy I replied to your remark in a private message.
Post by: Shug Emery on August 19, 2018, 09:23:02 PM
That is a right good looking airplane.
Post by: Roy DeCamara on August 19, 2018, 11:54:44 PM
Well, I thought I was just an old senior kidding a couple of old seniors over some of our fables.  Guess not as it pissed them off instead.
Keith, I apologize for my remark.  It was not my intention to insult you.  I thought you knew me better than that.  Again, I apologize.
As for Mike, since you threaten me, I"ll just pass you off as a poor sport IMHO.  Oh by the way, cancel my order for the Frisky Pete.
Post by: Mike Griffin on August 20, 2018, 08:11:05 AM
My pleasure Roy.
Post by: john e. holliday on August 20, 2018, 10:15:32 AM
Thanks Roy for your remarks as I too wonder if guys as well as me really comprehend what we are reading.  I am surprised I didn't get hit with comments about the post greatest stunt plane never published.  Maybe run into you again some time. H^^
Post by: Brent Williams on August 20, 2018, 11:49:05 AM
Nice plane!  Did you take any pictures during the construction process?
Post by: Paul Wood on August 20, 2018, 03:23:36 PM
Mike,
I used the R/C carb because I only fly for fun, not competition and I've had good luck using the R/C carbs on several other engines. I ran this engine on a test stand to establish fuel burn numbers with the carb set open. But, I may close down the carb barrel a little at a time if needed during flight testing. I've used the remote needle location in the past with good results. I have a C/L venturi/needle if needed, but based on past experience, this should work fine for my type of flying.
Post by: Paul Wood on August 20, 2018, 03:33:31 PM
Brent,
I only took a few photos of the bellcrank system during construction. It was the first time I used the self correcting "V" type bellcrank and I wanted to be able to duplicate the system on another plane if I like this type of bell crank. Sorry, no other photos except the flap construction posted in my original post.
Post by: mike londke on August 20, 2018, 06:08:01 PM
Mike,
It's a beautiful plane, good luck and have fun with it. #^
