  • July 17, 2025, 03:05:29 AM
Author Topic: McCoy lost power!  (Read 3267 times)
Offline Larry Wong
McCoy lost power!
« on: December 21, 2020, 07:55:56 PM »
This happen Sunday to one of are flyer , RM was covered with shrink wrap for shipping.
Larry
Re: McCoy lost power!
« Reply #1 on: December 21, 2020, 09:33:45 PM »
Did some one forget to tighten head screws or the thread strip? ???
Offline Larry Wong
« Reply #2 on: December 21, 2020, 10:10:32 PM »
From the looks, it was from a estate sale collector, engine was taken apart and the person assembled it not knowing 3 long bolts hold cylinder and head and 3 short bolts hold the head.
« Last Edit: December 22, 2020, 06:07:40 AM by Larry Wong »
Larry
« Reply #3 on: December 21, 2020, 10:17:02 PM »
When they said "drop the liner", they didn't mean in the weeds.
Offline Brad LaPointe
« Reply #4 on: December 22, 2020, 05:58:37 AM »
I never have seen a McCoy with enough compression to do this . Must of been a piece of metal jamming the top end .
Brad
Offline frank mccune
« Reply #5 on: December 22, 2020, 06:56:18 AM »
     To think that only I had unique engine problems!  Seeing this post makes me feel much better. Lol
      Frank
Offline Carl Cisneros
« Reply #6 on: December 22, 2020, 09:51:15 AM »
I had that pretty much same thing happen way back in around '74.
Running my buster in a club race with a McCoy 35 Series 21 on it.
Was using 25% nitro fuel and a 9 something prop on it.
It started to wind up more so than usual then all of a sudden, complete silence and we all saw the top end leave the motor.
Found the long screws had broken flush with the case.
Everyone had a good laugh.
Carl C
Carl R Cisneros, Dist IV
Control Line RB
« Reply #7 on: December 22, 2020, 10:25:40 AM »
  I had the same thing happen with an Olhsson 23 Sideport, it had no compression to speak of, either. The 35% nitro might have had something to do with it.
« Reply #8 on: December 22, 2020, 10:44:08 AM »
70 year old pot metal bolt holes.
   It's aluminum, not pot metal, but after 70 years of everybody thinking they are engine genii, who knows what state it is in.
« Reply #9 on: December 22, 2020, 11:33:42 AM »
Obviously, not enough castor oil in the fuel. That defect in the propeller probably didn't improve the thrust, either.  LL~ Steve
« Reply #10 on: December 22, 2020, 02:41:51 PM »
What do you think pot metal is according to the metric system.
  Pot metal is not defined (just whatever easily-meltable non-ferrous mix they have that day) but is largely zinc. Old Perfect wheel hubs were pot metal.
« Reply #11 on: December 23, 2020, 10:56:14 AM »
Same failure mode as my dad's last McCoy 40 on his Dewoitine D520.  In his case stripped bolts.  Died in OH8, got just enough recovery to put it in a pancake position, broke much more than prop...
« Reply #12 on: December 23, 2020, 04:20:37 PM »
     I remember that airplane, it was at the first contest I ever attended - as a 10-year-old spectator. It didn't crash that day, but I don't think it won, either.
Offline GallopingGhostler
« Reply #13 on: December 23, 2020, 10:13:09 PM »
Those bolts only go in one way. The longer will not fit unless aligned with the threaded holes in the crankcase. No one disassembled engine prior to mounting, just to make sure assembled correctly? I had an RH that someone mounted the piston backwards where the piston top baffle was on the exhaust side instead of the bypass side.
« Reply #14 on: December 24, 2020, 12:18:03 AM »
I read this post because the the title read "McCoy lost power"???? I want to know just exactly where did you get your hands on a McCoy that had power???
« Reply #15 on: December 24, 2020, 12:28:19 AM »
   I am pretty confident that it had less power after the cylinder flew off. But not certain.
« Reply #16 on: December 24, 2020, 03:30:05 AM »
Someone mistook it for a Fox .15 and attempted to throw it? <= %^@
Offline John Park
  • Agricola
« Reply #17 on: December 24, 2020, 05:57:38 AM »
I once tried a compression-restoring trick on a clapped-out Testors McCoy .19 - the one where you put the piston, skirt down, on a surface plate, hold a piece of 1/4" brass rod centred on the crown, and deliver a couple of smart blows with a hammer. Astonishingly, it seemed to work: the engine started easily, and ran well enough to fly a lightly-built SNAFU Magician through the old-time British stunt schedule at Old Warden in 1976.
« Reply #18 on: December 24, 2020, 07:31:28 AM »
I once tried a compression-restoring trick on a clapped-out Testors McCoy .19 - the one where you put the piston, skirt down, on a surface plate, hold a piece of 1/4" brass rod centered on the crown, and deliver a couple of smart blows with a hammer. Astonishingly, it seemed to work: the engine started easily, and ran well enough to fly a lightly-built SNAFU Magician through the old-time British stunt schedule at Old Warden in 1976.
   I think this has been posted before, but I think you are supposed to put the piston in the cylinder at the bottom like you describe, and then repeatedly peen the crown near the edge all the way around with the brass punch. Then you may have to lightly lap the piston back into the cylinder a bit before trying to run it. I think Jim Kraft has done this so you may want to include his name in the search for it.
  Type at you later and MERRY CHRISTMAS!!!!!
« Reply #19 on: December 24, 2020, 07:36:41 AM »
They had plenty of power for an engine that was basically crap.  Back in the day a money strapped teenager had two choices, an expensive engine that underpowered your Nobler and would last till you crashed and ruined it or a cheap one that would last till you crashed and ruined it.  If you could manage to get a McCoy broken in before it wore out, it was just as good as a Fox for it's expected life. LL~
Offline John Park
  • Agricola
« Reply #20 on: December 24, 2020, 09:49:58 AM »
I got my .19 for nothing!  A friend had flown it in a succession of British combat models (3.5cc max. engine size) until it had next to no compression, so I tried the crude fix described above. It had about as much power as a plain-bearing 2.5cc diesel when I ran it on 5% nitro fuel - which was all I could afford in those days!
« Reply #21 on: December 24, 2020, 10:31:54 AM »
  I know you are trying to be humorous, but the Hurl Committee takes a dim view of such levity when it comes to a blatant violation of Rules 68/69. We believe that sufficient controls are in place to eliminate such shenanigans with respect to official Hurl competition, and I am sure that no one here wants to leave any sort of misapprehensions when it comes to sanctions for such violations.
    The Hurl Committee/Moderna vaccination program is, of course, front and center, but I am sure we can spare some time to dispense the necessary directives to handle any such violation. Please do not take this opportunity to play fast and loose with The Rules, or there will be consequences.
    Thank you for your continued interest in the international sensation known as The Hurl!
    Brett Buck, Deputy Commissioner of the Hurl (self-appointed)
