General control line discussion => Open Forum => Topic started by: George Grossardt on March 17, 2021, 11:40:16 AM
I am looking for an engine test stand. Anyone have any experience with the Mayatech engine test stands that are listed on eBay?
Looked at the Mecoa stand and the one listed on the Brodak site (yikes, it’s expensive). I am open to other suggestions as well.
George
I bought one. pretty good. I mounted a k and b 28 on it and it was more than adequate. I mounted it with larger screws than were supplied with it. On Amazon for $26.99 with free shipping.
I would buy another one if I needed it.
The biggest thing I see is the clamps are in front of the engine and could give a clearance problem on some engines. Getting the engine as far forward of the mounting surface helps big time. If using a chicken stick on a small engine it may be less user friendly.
The tatone has low profile clamps held by 1/4" through bolts and each has one roll pin for the rear mount holes. It has only one clamp that slides for width...no dicking around with two loose pads. For the same money I'd buy the tatone on ebay.
I bought one that is all but identical to this one a couple of years ago from a guy in England (this one looks to be a copy of it). It works well for larger engines (.35 and bigger) but does pose a clearance on some engines... both prop and NV clearance. It does not have a pin but those are easy to add yourself. A few personal mods will make this mount good for 90%+ of the engines you use.
