  • July 20, 2025, 08:37:06 AM
Author Topic: Restoring an old thunderbird - Bob Palmer's Tribute  (Read 9216 times)
Offline Miguel Poduje
« on: December 09, 2014, 11:16:03 AM »
Hi, My Name is Miguel Poduje, from Chile. I want to post my Thunderbird restoration Job posted in others control line forum.. but i thik this is the right place to share my experience.
Please, excuse me about my english, i try to do the my best, without using google translator because i know the results are more incomprensive than tarzan's english  ;D.
many years ago, my father built a thunderbird from an old kit. he flew this model for many years, receiving two top overhaull. Then this model was stored in a warehouse and was there for a long time (more than 15 years). My father put the house for rent, leaving the old thud forgotten in time in that darkness.
A few months ago, we went to the house and discovered that the old thud was still there hanging on the wall, very dirty and semi destroyed but in much better shape than I thought.
The first thing I did was take it and take it home, talk to my father about the many memories we had of that plane and try to find ways to put it off again.
Two weeks ago we started the reconstruction of the old Thud and here I leave some pictures of this process that I hope will end soon and the old Thud back to fly again after more than 30 years.
The wing had a twist, but we are solving wetting the wood and insert webs  between the spars. The flaps must be changed and we are still thinking about what to do with the nose that is too impregnated with fuel.
This Tbird had the engine up and the cowl was lost. Now I'm thinking if it's better to do the same or do the version with radial cowl. My intention is to paint as the original Bob Palmerīs Tbird (white, red and black), even place the same letters AMA 19488 in the wings.
I could not find good pictures of Palmer's TBird, i have not found good pictures with the radial cowl version. Anyone have any good photo to use as a guide?
More photos.
Re: Restoring an old thunderbird - Bob Palmer's Tribute
« Reply #1 on: December 09, 2014, 11:20:10 AM »
Ok friends.
I decided to improvise on the radial cowl. This weekend I will visit a craftsman who had a wood lathe in order to build the master which will i do the mold in fiberglass. The advantage, is if i making the mold, i can do several tests to find the best solution that i want. Thanks for all your attention to my project. I will keep you informed.
i post these new photos showing the tbird progress, I hope that the pieces purchased in brodak arrive soon. This Saturday I'll go to the wood craftsman to make me the master of the cowl.
Thnaks !!
I just received the master mold to build the fiberglass cowl. Now need a lot of polish work  to get it ready to start work in fiberglass.
We are in the best stage !!!  Dope !!!:p  :D
We have received the polyspan from BJMR  models ... I must say I have been very impressed with polyspan, I was accustomed to using silkspan but this is much easier and much better result. We are now in the hard work ... dope, sanding,  dope, sanding, dope, sanding, dope, sanding, dope, sanding, dope, sanding....:cool:
You can see that the fuselage sides are curved and are waiting to dry.to dry in place.
more photos here
« Reply #2 on: December 09, 2014, 11:21:20 AM »
New Pics !!!!
« Reply #3 on: December 09, 2014, 11:22:32 AM »
 All plane are covered with polyspan, ihave some troubles with bubbles, but workerd hard with sandpaper an dope to eliminate all.
Now, the plane are readey to paint. I bought poliuretane paint  with a little change in the colors... i replace the red with a metallic italian red, the white will be a "cream" wihite... this colors looks more classic  .
« Reply #4 on: December 09, 2014, 11:23:23 AM »
So far the progress in painting have been few because the weather in Santiago is not good. We have done some testing but  the humidity  affects the paint job.
For now I have been working on the logo and these are the results.
If anyone wants these files in adobe illustrator, send me a message and I will gladly send them.
Original from the "Control Line Manual" book
Vectorized logo , to send to vinyl cutter
Vectorized image to print t-shirt
« Reply #5 on: December 09, 2014, 11:24:11 AM »
is very difficult to paint with poliuretane and this weather...
You can see i replace the original colors (white and red) with a more classical creme and metallic dark red.  The schema will be the same as the original Bob Palmerīs Thud.
« Reply #6 on: December 09, 2014, 11:25:04 AM »
Masking and Painting
[img ]http://i704.photobucket.com/albums/ww42/mpoduje/Thunderbird/20140628_160051_zpsngwntoyo.jpg[/img]
« Reply #7 on: December 09, 2014, 11:25:42 AM »
I had a lot of problems with humidity, you can see a liitle bubbles in the black painted stripes. I don`t know how i will repair this bubbles, but i`m sure i will get the solution.
« Reply #8 on: December 09, 2014, 11:26:22 AM »
Now, we are ready with the paint, and starting the polishing. I hope the maiden flight will be at Nov. 8 because in our club we have the aniversary festival.
Bye!!
« Reply #9 on: December 09, 2014, 11:26:51 AM »
More pics, now starting the decoration..
« Reply #10 on: December 09, 2014, 11:27:35 AM »
It was hard work but we enjoyed it a lot, now we just need to put the canopy..
« Reply #11 on: December 09, 2014, 11:28:15 AM »
The final weight is 1420 grams.  Off course, the engine is heavier than old foxs or vecos, then i reduce the nose arm 1 1/2 inches in order to balance.
MAIDEN FLIGHT !!!!
In windy conditions, last saturday i did the first fly of  the Thud. Very stable and the engine works fine...  no manouvers in this flight , because the wind was hard and turbulent.
Great flight !!!  i'm very happy, the restoration are finsh,
VIDEO  Sorry... there is another video, but i need to edit, maybe this afternoon
« Reply #12 on: December 09, 2014, 11:28:58 AM »
a better video....
Before - After
Offline Leester
« Reply #13 on: December 09, 2014, 11:46:16 AM »
Great job Miguel !!! Absolutely Beautiful plane.. Thanks for sharing
Leester
ama 830538
Offline James McKinney
    • MACA Website
« Reply #14 on: December 09, 2014, 12:50:13 PM »
wow! Nice job!
Offline goozgog
« Reply #15 on: December 09, 2014, 02:01:35 PM »
Miguel - The plane looks excellent!
   Knowing that it has a long history
with your family makes it extra special.
Congratulations! y1
Cheers!
Keith Morgan
« Reply #16 on: December 09, 2014, 04:05:55 PM »
Nice job BUT I hope you did not reuse that plastic elevator horn.  ~^They were bad when new. Now it is old it will fail very quick. The plastic vertical arm came loose from the metal arms. It was criminal to even sell them.
 Tell me you did not use it. What about the flap horn??? n1
« Reply #17 on: December 09, 2014, 06:12:54 PM »
Miguel,
Outstanding!  H^^
I can relate to your restoring that model with changes.   ;D
PM sent for that Illustrator file.
Good work!!
Charles
Offline Douglas Ames
« Reply #18 on: December 09, 2014, 06:24:44 PM »
Nice save!
The graphics look great, especially the sponsor decals. Very tastefully done.
AMA 656546
« Reply #19 on: December 09, 2014, 06:51:22 PM »
Thanks for your words...  sorry again for my english  i try to do my best. I'm very happy with this restoration because is a excellent work with my father that did more than 80% of work, and my son that worked on graphics for me.
Thanks again.
Ed, don't worry, we replaced all horns, and pushrod. The bellcrank is trhe same, because is an old and original veco part, only replace the brass bushing, bolt and cables.
Miguel.
Offline Mike Keville
« Reply #20 on: December 09, 2014, 07:05:03 PM »
Miguel:
Beautiful save!  Thanks for sharing with us.
And there is nothing wrong with your English ... in fact, it's much better than many of my own citizens!   LL~
Offline Keith Miller
« Reply #21 on: December 09, 2014, 09:33:20 PM »
Nicely done, sir!
