I take a spool of .015" wire, make an end on the free end, attach 2 line clips to the chain link fence in the front yard, attach the made end to one of the clips, run out about 6" more line than I want, repeat for other line, Measure exact line length plus 3", cut both lines even, make both remaining ends. Attach handle and torture test lines (about 50% over normal pull test). I have had only one line fail since doing this. I would rather they fail now than while flying. I only crimp lines, never wrap. I used to wrap leadouts, but gave up on that long ago.
