  • June 19, 2025, 07:12:03 AM
Author Topic: Alignment tool  (Read 2365 times)
Offline Perry Rose
Online Paul Taylor
Re: Alignment tool
« Reply #2 on: August 21, 2024, 09:18:51 PM »
$70????
       I see 4 lengths of carbon push rod tube held to the elevator with masking tape!!  The photo shows them being used on a giant scale 3D acro model. They use a servo for each elevator mounted at the back of the airplane, so you need something to help you align the two halves. 4 straight sticks and some tape will do the same job,
Offline Perry Rose
Re: Alignment tool
« Reply #3 on: August 22, 2024, 07:36:41 AM »
Not masking tape. Strong magnets. The tape looking stuff is to protect the finish.
Re: Alignment tool
« Reply #4 on: August 22, 2024, 01:40:35 PM »
  Yes, I realize that. But 4 straight sticks and some masking tape can do the same job. The sticks could be long enough to go further up on the elevator to give a better representation of where the whole surface actually is. It's kind of necessary on those giants, not so much on smaller models. And i agree with Paul, 70 bucks!!!??? The world needs more quality 2" spinners more than it needs these !!
Offline Perry Rose
Re: Alignment tool
« Reply #5 on: August 23, 2024, 07:35:06 AM »
Here's another tool for you. I've been holding off buying another Robart incidence gauge. This adapter fits the Robart bar and with a Wixey Angle Gauge ,separate, is much more accurate. Costs about the same and makes more sense.https://www.ckaero.net/products/digital-angle-meter-mount-for-robert-anglepro-incidence-bars
