  • July 15, 2025, 09:21:55 PM
Author Topic: Magnum White 4" Bellcrank  (Read 1228 times)
Offline Ian Hewitt
« on: November 05, 2020, 03:35:27 AM »
Hi Stunt Hangar,
I have a nicely built Magnum wing which appears to use the white 4" SIG bellcrank. I was wondering whether there have been any problems reported with this item as it appears to be much lighter than the black 4" Sig Pro bellcranks that I have.
I would prefer not to tear down the wing to replace the bellcrank but will do if necessary..  ..be grateful for any advice.
Thanks in advance.
Ian
Nottingham
Offline RC Storick
Re: Magnum White 4" Bellcrank
« Reply #1 on: November 05, 2020, 09:55:34 AM »
Are the lead outs bushed?If so I would run with it.
Offline ericrule
« Reply #2 on: November 05, 2020, 10:29:06 AM »
Sparky is absolutely correct! The Sig 4" white bell crank is nylon and will work quite well in your Magnum. Problem is that unless you bush the lead out holes the wire will saw through the nylon.
« Reply #3 on: November 05, 2020, 10:52:14 AM »
Hi Stunt Hangar,
   Those are generally just fine.
Offline Ian Hewitt
« Reply #4 on: November 05, 2020, 12:52:39 PM »
Many thanks for the feedback.
I'm pretty certain that the experienced builder installed copper tubing on the leadouts through the bellcrank.
I will check this out but feel more confident now that the installation is good.
Another lockdown project to pickup.
Thanks again
Ian
« Last Edit: November 05, 2020, 04:10:04 PM by Ian Hewitt »
