  • June 20, 2025, 06:31:11 PM
Author Topic: Cox Gasket Needed  (Read 1797 times)
Online Jay
  • 1 Cross +3 Nails= 4 Given
Cox Gasket Needed
« on: September 16, 2006, 08:36:48 PM »
Hi guys.
I am in desperate needs of the Cox .049 gasket.  The paper gasket  that goes between the tank and the crank case.  I need about 10 of them as most of my motors are in need of replacement.
Any of you guys out in Stunt land have some or know where I can get some?  I am willing to pay.
Thanks in advance
Jay
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
Offline Garf
    • Hangar Flying
Re: Cox Gasket Needed
« Reply #1 on: September 16, 2006, 09:36:21 PM »
One of the Ebay specialists is selling them, but they aren't cheap.
Offline Bill Adair
  • AMA 182626
« Reply #2 on: September 16, 2006, 10:09:50 PM »
Jay,
I've used high temp RTV (red) to seal engine parts, when gaskets were not available.
Worked great for me, but you do have to watch clearances, as the parts may pull closer together than with a gasket.
Has anyone else tried RTV, in place of gaskets?
Bill Adair
Offline Richard Grogan
« Reply #3 on: September 16, 2006, 10:38:52 PM »
If you still have a motor with a good one, you can carefully take it off and trace it onto a index card, or other thin material. Or trace the crankcase's back..I think I once used the cover from a spiral notebook and worked just fine. Cut it out with scissors/ xacto and your done. Hope this helps and good luck!
Richard
Long Live the CL Crowd!
                  AMA 85745
« Reply #4 on: September 16, 2006, 10:41:21 PM »
Jay,
Bill Adair
Hi Bill,
Used the red RTV quite a few times.  If you are careful to make sure no "extra" gets inside where it ain't supposed to be, it works great.  y1
Bill <><
Offline jamtx
« Reply #5 on: September 17, 2006, 07:36:50 AM »
Try here  http://www.airfield2000.com/babebee049.html  they might have some left.
                                 james
James Karnes
Abilene,TX.
Online RC Storick
« Reply #6 on: September 17, 2006, 07:45:40 AM »
Hi guys.
Thanks in advance
Jay
Please follow these instructions to the letter!
  • Get some 3M 77 spray
  • Spray a thin coat on thin gasket material bought from auto parts store.
  • Stick it to th back of the case.
  • Take a small tack hammer and tap around the edge of the case to cut the paper.
  • After cleaning the edges with a sharp #11 blade re-assemble engine.
Its just that easy! It should take about 10 min. I hope this helps.
Online Jay
« Reply #7 on: September 17, 2006, 08:39:13 PM »
A special thanks to all who have helped me in my search.  While there were many good ideas  I wanted to get the Cox part.
A very special thanks to Ralph Wenzel for directing me to Dale Kirn.  Dale has all the gaskets I need for a real good price as well.
Check out his website.
http://kirn.hypermart.net/
Thanks Sparky for the board and allowing me to post.
Jay
Albert Einstein
  278622
Offline W.D. Roland
« Reply #8 on: September 22, 2006, 12:54:39 PM »
supposedly aluminum tape works good---head gaskets to--i havent tried it yet
the hamer method works good--would need realy small hamer for cox---possibly a 3/8 or 1/4 socket extension?
David
David Roland
51336
