  • July 18, 2025, 08:43:12 PM
Author Topic: Magnetic Building Board  (Read 1870 times)
Mike Griffin
« on: May 08, 2015, 09:08:13 PM »
Is any one using a magnetic building board to build control line planes ?
Offline Gary_Marchand
Re: Magnetic Building Board
« Reply #1 on: May 09, 2015, 09:54:59 AM »
Same experience as Ty.
Forever a beginner - Gary
Offline Keith Miller
« Reply #2 on: May 09, 2015, 04:42:21 PM »
I've used one on a couple of builds and find it much easier than pins in a board. Can't get pics to upload - something about size limits.
Offline big ron
« Reply #3 on: May 09, 2015, 05:39:31 PM »
There is a web site I think it's airfield models or something like that guy has a lot of info I think he built some of the doodlebug
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline dennis lipsett
« Reply #4 on: May 10, 2015, 03:04:57 PM »
I have used a Magna Jig for about 50 years. Wings are always straight and the structures are easy to align. I lent it to a friend who is particular about his models also and he was amazed at the ease in which the wing assembled.
Regrettably the magna jig hasn't been available for about 45 years but it is a heavy steel and wood assembly that cannot warp opens up to 6 feet and you can build an Al Rabe or Pat Johnson model with dihedral as it is two thirty six inch pieces. I also have about 300 magnets and after this many years I think I know how to use then more effectively than perhaps most other builders. Regrettably I don't have a rod type jig but I'm thinking of using one just to see if I'm missing anything.
I am assuming that the other responses dealt with smaller set ups than mine, As I have built literally hundreds of models on this board in 50 years.
Dennis
Mike Griffin
« Reply #5 on: May 10, 2015, 03:14:01 PM »
I am tempted to go buy a piece of galvanized sheet metal and try it .
« Reply #6 on: May 10, 2015, 05:59:55 PM »
Mike,
I forgot to mention in my last post it is not unusual to have the whole wing together and aligned on this board and then apply glue to the joints. Granted I do use 2 alignment sticks for the trailing edge but once the datum line is established then the magnets hold the part in perfect position, same for spars and ribs in general. I also generally have the leading edge positioned in place and have squared everything before permanently gluing the structure together. Rather simple and readily apparent to anyone with common sense to use it.
Dennis
Mike Griffin
« Reply #7 on: May 10, 2015, 06:03:51 PM »
Thank you Dennis for the information.  I need to find some 90 degree welders magnets that ar reasonably priced.
« Reply #8 on: May 10, 2015, 06:15:00 PM »
Mike,
You do not need 90 degree magnets. For ribs 2 on each  front and rear of the rib upright will  absolutely lock the rib in place. You won't take long to see how the other applications are handled as they are readily apparent.
Offline Allan Perret
  • Proverbs
« Reply #9 on: May 11, 2015, 10:39:51 AM »
If I was going to try magnetic building board I would build this one.  He has done a good job with the design and gives a lot of good info about sourcing materials.  You can also buy a system from him.
http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/tools/magnetic_building_board/index.htm
Allan Perret
AMA 302406
Slidell, Louisiana
John Gluth
« Reply #10 on: May 11, 2015, 01:46:07 PM »
Allen, Thank You so much for the effort to post this. Very helpful!
Sharing is the real purpose of StuntHanger.
« Last Edit: May 12, 2015, 05:49:50 AM by John Gluth »
