The Banshee should handle straight line wind OK. The big thing with straight line wind is placing the manuever correctly, and a high RPM/flat prop pitch set up helps a lot also in reducing the tendency for the airplane to whip up, or get remarkably faster in each of successive loops.
In turbulance, (and I haven't read Bob's article yet to see what he mentions on the subject,) I would want a model that is basically aerodynamicly clean as possible, and turns well in order to fly through the garbage as cleanly as possible, and to turn quickly to get you out of the trouble it may put you in. A Banshee should do as well and about any other airplane, especially with some of the moment modifications you can read about on the forums. If I were going to pick a model to fly in turbulance, I might pick one without flaps, just to eliminate the potential loss of speed in corners that you have to over come any way, and may be made worse by bubbley air. Flaps increase lift, but also increase drag and that is your enemy in turbulanace, in my opinion.
Just a thought. Like I said, I haven't read Bob's article yet.
