  • July 14, 2025, 03:28:20 PM
Author Topic: Thinner's  (Read 1862 times)
Offline Bootlegger
Thinner's
« on: June 17, 2010, 06:44:36 AM »
  #^  Mornin guy's, I need some suggestions/advice on thinning some Randolph's non-tautning clear dope, I am using dope thinner, but I need to slow the drying prosess down so it will flow out better.
  I am apprehensive about too much retarder as I don't want to melt the canopy.
  Sure could use some advice...    #^             Thank's Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Larry Fernandez
Re: Thinner's
« Reply #1 on: June 17, 2010, 09:10:18 AM »
Hello Gil, I have been using Dupli-color medium temp laquer thinner with great success.
I buy it at the local Kragen Auto Parts store for 14 bucks a gallon (much cheaper than $18.00 a quart for Brodak thinner)
Make sure it is the high VOC thinner and NOT the low VOC.      THE LOW VOC THINNER WILL NOT WORK!!!!!!!!!!
It will curddle and turn to snot in the jar after mixing
Give it a try and pass along your results to others. H^^ H^^ H^^ H^^ H^^ H^^
Larry, Buttafucco Stunt Team
Offline Bootlegger
Re: Thinner's
« Reply #2 on: June 17, 2010, 10:56:31 AM »
  Thanks Larry, This is used with Randolph dope right??
Gil Causey
AMA# 6964
Re: Thinner's
« Reply #3 on: June 17, 2010, 11:05:24 AM »
I have used it with Randolph, Certified, (taught and non-taught) Brodak and Sig. Color and clear.
I was mighty jazzed to find this stuff, as it is close, right around the corner, and cheap.
Mike Griffin
Re: Thinner's
« Reply #4 on: June 17, 2010, 02:31:39 PM »
Larry if I understood your post correctly, you said it would work with the colored dopes also??
Re: Thinner's
« Reply #5 on: June 17, 2010, 03:56:54 PM »
Yes Mike, I have used it with colored doped,Sig and Brodak. Give it a try and let us know how it works for you.
Offline Allan Perret
  • Proverbs
Re: Thinner's
« Reply #6 on: June 17, 2010, 04:07:13 PM »
Can you give us a product number from the can ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bootlegger
Re: Thinner's
« Reply #7 on: June 17, 2010, 08:18:14 PM »
             Thanks Larry, I appreciate your help..
Gil Causey
AMA# 6964
Re: Thinner's
« Reply #8 on: June 17, 2010, 08:50:58 PM »
Allen, the product number on the can is CM-502
Online Mike Scholtes
Re: Thinner's
« Reply #9 on: June 17, 2010, 10:07:59 PM »
Larry, this sounds too good to be true!
I use Randolph's buty thinner with Randolph's clear and successfully with Brodak and Sig buty color dopes, including Sig clear. Available from Aircraft Spruce in California, no problem getting it delivered. Not as cheap as the Kragen stuff but a lot less than Brodak thinner.
If Larry here believes in this product you KNOW it has to be good. Those of you who have not seen Larry's work are really missing something. I am probably embarassing Larry but he can handle it.
Offline billbyles
Re: Thinner's
« Reply #10 on: June 17, 2010, 11:44:18 PM »
Yep, Larry can really finish...I get to look at the back half of his Stuka every Thursday evening when I go to Warren Walker's for a barbeque/building session.  Unfortunately, I was there when Larry modified the Stuka so it could be mounted on Warren's wall.  Sad story but Larry took it in stride.
Bill Byles
AMA 20913
So. Cal.
Mike Griffin
Re: Thinner's
« Reply #11 on: June 18, 2010, 08:02:00 AM »
Thank you Larry for you help
Re: Thinner's
« Reply #12 on: June 18, 2010, 11:37:49 AM »
When Warren told me what he did with the remains of the Stuka I laughed my a$$ off. What an honor to be memorialized on the "Walker Wall of Shame" !!!!!!
You've gotta take some pictures of this and post it !!!
I'll see all of you clowns next weekend at the Joust.
« Last Edit: June 18, 2010, 08:24:33 PM by Bill Little »
Offline billbyles
Re: Thinner's
« Reply #13 on: June 20, 2010, 08:36:00 PM »
I will try to remember to take a couple of photos of it on Warren's wall and post them here.
Bill Byles
AMA 20913
So. Cal.
