Somehow I am going to blame George Bush for this, but I have not quite worked out the details yet....
failure mode is not the same as the first airplane. In this case the keeper washers fell off both ends of the elevator pushrod, and once the failsafe retainer wore away it came unhooked at the flap horn. The contributing factor was a piece of music wire that for some reason would not take solder despite exhaustive cleanings, not even acid flux would make solder reliably stick. In hindsight I should have pitched the pushrod and made up a new one. The new plane uses ball links instead of soldered wire....
