  • July 17, 2025, 12:36:14 PM
Author Topic: Loose on insides  (Read 2404 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
Loose on insides
« on: October 06, 2006, 06:35:14 AM »
Have a stunt ship that gets a little loose on insides, not terrible just enough so you can tell a definite difference bettween line tension on inside loops verses outside loops. Outsides are great...
I have tweaked the flaps both directions in case it might be a slight wing warp or flap misalignment, didn't help but sure had the wings flying at funny angles. The stab is straight and square, tip weight is good, turns flat in a hard corner etc. Good overhead tension, leadouts may need to be moved a tad forward but it's close..
Had another pilot fly it just to make sure I wasn't chasing a ghost and he came to the same conclusion. Only difference was he felt it turned tighter outside than inside and I think it turns tighter insides.. This is probably just our brains playing tricks.
Any ideas on the loose insides ????
Online RC Storick
Re: Loose on insides
« Reply #1 on: October 06, 2006, 06:56:11 AM »
Check parallels of hing lines.
Offline Bob Reeves
« Reply #2 on: October 06, 2006, 09:57:05 AM »
First thing I checked, they are right on the money.
I never have normal trim problems, always something weird.
Offline Charlie Pate
« Reply #3 on: October 06, 2006, 10:13:21 AM »
Bob
The plane I flew at the Memphis contest does Exactly the same thing.
 Its ,as yours, not really bad but definatly different.
 I have tried the same things as you , with difference, but not the right diference.
I have the hinge lines sealed from the start and its a better flying plane than pilot.
but just  a bit lite on the insides.
By biasing the manuever left, I am O.K. , but not correct.
 If you correct the problem PLEASE let me know.
Thanks %^
Offline Bob Reeves
« Reply #4 on: October 06, 2006, 11:01:57 AM »
Hi Charlie.
Maybe we can come up with what is similar between the two that may be contrubting to the light insides. Mine is the Skylark I just put the ST 51 in but it did it before I switched engines..
It has a slightly larger outboard flap with about 1/2 inch of wing offset, airfoiled non adjustable rudder and everything I can measure says it's a straight airplane. Other than this little quirk it flys fantastic.
Probably wouldn't bother me except I don't always hit the wind exactly right, sometimes around here it's impossible as it can seem to come from two directions at the same time  :o
Offline Richard Grogan
« Reply #5 on: October 06, 2006, 11:09:05 AM »
Bob,
Did you put any offset on the engine?
Long Live the CL Crowd!
                  AMA 85745
Offline Bob Reeves
« Reply #6 on: October 06, 2006, 11:21:52 AM »
Bob,
Good question, just enough to know it isn't pointing in, maybe 1 deg.
« Reply #7 on: October 06, 2006, 11:39:03 AM »
Try maybe 2 or 3. It might be the extra spice thats needed ! It'll at least add an constant to help eliminate a slight fuse bend that you might not be able to physically see.Probably more to it than that, but just a thought! :!
                  AMA 85745
« Reply #8 on: October 08, 2006, 07:48:25 AM »
Something I haven't seen mentioned:  is the front leadout your up line?   DOC Holliday
Offline Allen Brickhaus
  • ACE
« Reply #9 on: October 08, 2006, 08:01:12 AM »
You might try more or less hinge sealing tape on the flap gap.  Simply do all of one and less of another.  This tape should come off easily after each flight.
Another solution might be if your vertical rudder is tilted one way or the other.  Check that also.
Allen Brickhaus
  • ACE
« Reply #10 on: October 08, 2006, 08:02:57 AM »
Tom Hampshire suggested that you might have the leadouts too far forward.  Check trhat also.
Allen Brickhaus
Offline Bob Reeves
« Reply #11 on: October 08, 2006, 11:27:59 AM »
Allen Brickhaus
May be... I removed a ST 46 and installed a ST 51, net result was adding an ounce to the nose. Didn't change the leadout position and the problem didn't change, it did the same thing with the 46. The up line is forward and could be I had them too far forward even with the 46 but would think adding an ounce to the nose would change something or make it worse. Just thinking out loud.. The leadouts with the 46 were set using LineII which ended up right at 1 inch behind the CG.
I have since moved them a little farther forward as the CG moved forward with the engine swap but haven't flown it yet, will try moving them farther back... maybe this evening or tomorrow if I get done with todays honey-do's.
Thanks for trying to help guys, this one has me baffeled.
  • ACE
« Reply #12 on: October 08, 2006, 11:30:02 AM »
Make small changes at a time and return to a better setting if what you have done is to the detriment to the trim.
Allen Brickhaus
« Reply #13 on: October 08, 2006, 06:36:05 PM »
It probably has a warp.  Tweak the wing until the tension is equal on inside and outside maneuvers.  I'd recommend keeping the flaps straight and twisting the wing.  Having the flaps at different angles adds another assymetry to the plane that you have to trim out.  It's a quick fix for slight warps, but dewarping the wing is better.  Once you get the wing straight some other undiagnosed problem may be easier to spot.
Offline Bob Reeves
« Reply #14 on: October 09, 2006, 03:57:12 AM »
Hi Phil,
Understand what you are saying but this is probably the straightest airplane I have ever built. First thing I did when I noticed the problem was block it up on my building bench and measure everything.
Have to put breaks on my van today and it's supose to rain tomorrow so may be a few days before I get back to it
« Reply #15 on: October 09, 2006, 08:00:10 AM »
Bob, you can't measure the plane as accurately as the air flows over it.  unless you find something else, there is uneven airflow over the wing, causing it to roll.  Could something as simple as getting a VERY  slight bias in cutting the ribs and ending up with just a touch of up camber in one wing and down camber in the other.  I see that in the current batch of combat planes I'm building.  Virtually every one comes off the building board with a very slight right roll- actually kind of nice for a combat plane.  At least it won't roll into the circle on take off.  They're glued together on a jig and as straight as possible.  But with all the fuzzy edges on the foam etc. it's impossible to measure the wings as anything but straight.
If you don't want to warp the main panels, glue a trim wedge on the bottom of the appropriate wing.
Offline Bob Reeves
« Reply #16 on: October 09, 2006, 09:01:02 AM »
Good point Phill... Something is causing it.. Going back to square one, starting with going through bench trimming and see if it ends up with the same problem. If it does I will follow Allens advice and only change one thing at a time..
Bob
