Here's an update after 2 more flying sessions.
I used a heat gun to slightly twist the wing to get the wings level. And I mean slightly.
I had 3/4 oz tip weight to start with and removed 1/4 oz. Much better.
Fabricated a new elevator horn. The old horn had the holes lined up with the hinge line but was not 90 degrees to the push rod. So it gave me more down than up. Made a new horn that is 90 degrees to the push rod and has the holes lined up with the hinge line.
Went with a 11 1/2 inch prop instead of 12 inches. Battery draw after a 5 1/2 minute flight is anywhere from 1400 to 1450mah. Or 78 to 80%.
Still has the 2 ounces of nose weight. New batteries have been ordered.
The airplane is flying decent now with only 1 exception. And the is the 3rd corner of the Hourglass. The outboard wing drops during the corner. It drops enough so I can see the bottom of the outboard wing. Even when I go easy on that corner it still drops, not as much when I hit hard , but still drops. Everywhere else in the pattern the airplane handles well. Any ideas as to the cause and fix would be appreciated.
The overall thoughts are it is a very good flying airplane with a very nice corner. Unfortunately, it suffers the fact that in a nice square corner, it does not want to stop turning. A common problem with flapless stunters. I found myself overturning most square corners because of this.
