  • June 27, 2025, 01:53:02 PM
Author Topic: Engine Running Stand  (Read 3240 times)
Offline Garf
    • Hangar Flying
« on: July 02, 2009, 12:53:47 PM »
I have just been running some engines trying out the Omega fuel I just bought, to see if it would run in my older engines. I believe it will only work in my ABC, ABN, AAC or AAP engines. My Fox Rocket didn't like the stuff at all. I hope my gallon of castor oil gets here soon. I think my running stand has about had it. I can picture it falling apart any time now. I need to find a design that is light, simple, and strong, preferably foldable. Any ideas?
Eric Viglione
Re: Engine Running Stand
« Reply #1 on: July 02, 2009, 01:52:54 PM »
My Bucket-O-Bricks stand would never pass the "lightness" test, but it'll hold down even the gnarliest PA!  LL~
I just have a Tatone stand bolted to a sheet of marine plywood, bolted to the lid of a 5 gal bucket filled with bricks.
Works for me, and gets all kinds of strange looks from the R/C guys at my field.  n~
Here's a shot of one of my PA61's breaking in on a header muffler.
EricV
« Reply #2 on: July 02, 2009, 03:52:59 PM »
I use an aluminum unit that was patterned after the old EZ-Just test stand. That's bolted to a chunk of 3/4" pressboard that is clamped to the old picnic table in my backyard. Has a 20 ounce ducted fan tank for fuel. Sort of goofy looking curved stand up job.
Offline jim gilmore
« Reply #3 on: July 02, 2009, 06:03:40 PM »
Randy, does that mean you can break an engine in in 1 tank full ?
Offline Bill Heher
  • Fix-it
« Reply #4 on: July 02, 2009, 08:45:32 PM »
I have used various pieces of 3/4 plywood with a notch cut to receive the engine, clamped in my M.I.C. ( made in china) copy of a Black and Decker Workmate.
It folds up when not needed, and is handy for lots of stuff besides test stand. A 2X4 thru a cement block and across the bottom braces of the legs keeps it from tipping. You can find them at Harbor Fright, Wally World, Home Despot, etc for about $25.
Bill Heher
If it's broke Fix-it
Offline Ralph Wenzel (d)
« Reply #5 on: July 02, 2009, 09:06:32 PM »
Until recently, I always used a 2-step ladder (wood) painted with 1 or two coats of polyester resin, and with a Tatone (or the newer Brodak) test mount bolted to the top. Total weight about 4 pounds, folds flat, etc. Put a 25# bag of sand on the bottom step and it'll hold anything you're likely to run.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #6 on: July 02, 2009, 10:20:35 PM »
Jim,
No, I just don't have to fill it as much.   ;D
Offline Michael Boucher
« Reply #7 on: July 06, 2009, 02:42:50 PM »
Eric, I like your Bucket O-Bricks stand, cool #^
AMA 59633
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« Reply #8 on: July 06, 2009, 03:28:44 PM »
Garf,
I use a standard engine test bracket from Brodak. I put it on an old Dremel jig saw stand, (think you can get similar stands from local hardware stores). This way it's at a higher level and I don't have to stoop much to use it. Also, heavy enough for up to .51 motors. It's not foldable, but slides away pretty easy. Would need a little weight on the base for larger bore engines. It tends to "walk" a little with the ST.51 with rev up at end of tank. LA 40-46, no problems with stability.
Most expensive part was the Brodak bracket, I think $49.00
http://www.brodak.com/shop_search.php?productsearch=engine+test+stand
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
« Reply #9 on: July 10, 2009, 05:09:59 AM »
That's a cool test stand as well. :)
AMA 59633
Offline Ed Prohaska
« Reply #10 on: July 10, 2009, 09:59:04 PM »
How is this for an engine test stand: A Dumas Big Swamp Buggy! I built this in the late 1980s when I was "corrupted" by an R/C field 3 miles from my house. The Futaba Attack 4 radio died about 10 years ago and I never got a new one. I've used it for ground running engines ever since.
The engines mount on a removable crutch. I made up 4 of these to try different engines when I was still running the air boat. It usually ran with a K&B .61, but I used a LA .40 and a .46 when those first came out. I have crutches for engines I no longer own like the Fox .50 and Merco .61, but some can be modified to accept different engines. The yellow one now accepts the FP/LA .35 to .46, Super Tigre .46, Stalker .40/.46 and my GMA Jett 50. I can't run a prop larger than 12 inches, but normally use a 10 or 11 inch prop for break in anyway.
One nice thing about the airboat: the finish of Hobby Poxy and K&B Super Poxy over polyester resin is highly fuel proof.  It will probably be around long after I'm gone. I would never have built this boat just to ground run engines, but since I have it, I use it. Regards, EWP
Offline andreas johansson
  • SWE-56998
« Reply #11 on: July 11, 2009, 03:05:07 AM »
The mighty king of , and the worlds ugliest, test stand  ;D http://stunthanger.com/smf/index.php?topic=2966.0
/Andreas
Nobler-O-Maniac
SWE 56998
Offline George
  • Love people, Use things.
« Reply #12 on: July 11, 2009, 06:31:33 AM »
Agreed...but it works! ...and as one of the posters on that site said, "Reuse beats recycle every time."
George
George Bain
AMA 23454
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #13 on: July 11, 2009, 11:58:48 AM »
/Andreas
Been following this thread and trying to decide if I should mention "Worlds Ugliest Test Stand".. You saved me the embarrassment  LL~
It ended up getting painted (more or less) when I painted my flight line tractor, good place to squirt left over paint. It's still very functional and has ran a bunch of engines, no signs of vibration fatigue and holding up well even though it lives outside.
Offline Bill Gruby
« Reply #14 on: July 11, 2009, 12:20:50 PM »
 Long as we're lookin at them -- here is mine. This one is a Dynamometer,
  "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Offline Bill Adair
  • AMA 182626
« Reply #15 on: July 11, 2009, 12:46:05 PM »
Bill,
That is an amazing set up. Did you design it, buy it, or build it from plans?
  • SWE-56998
« Reply #16 on: July 11, 2009, 12:53:18 PM »
Bob: Every time I feel a little depressed or stressed I read the thread about the WUTS(tm) and it always cheer me up.  #^
I hope that the paint didnt make it look less ugly?
/Andreas
Nobler-O-Maniac
SWE 56998
Offline Bill Gruby
« Reply #17 on: July 11, 2009, 03:02:50 PM »
Bill,
 Bill ---  I got this Stand as a kit from a gentleman in Massachusetts. I will dig out the info on it if you wish. He only made 12 of them and saved one for me. This is how it comes.
  "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Offline Bill Adair
  • AMA 182626
« Reply #18 on: July 11, 2009, 03:17:29 PM »
Bill,
Looks like a great piece of test equipment. How does it work for you?
Doubt I can afford one, but it doesn't hurt to ask the builder, so I'd appreciate the info if it isn't too much trouble to find.
I like fiddling with engines, and bench running stuff like that, almost more than flying! It's not supposed to work that way!  ;D
Offline clscale7
« Reply #19 on: July 17, 2009, 10:44:49 AM »
I use my test stand enought I made from surplus plywood, food cans from my recycling bin and lag bolts. I have my test stand set up with two mounts, one for smaller engines and another for larger engines. The stand weighs less than 12 lbs but even with a .60 or .90 at full bore it doesn't move. I also have a throttle linkage setup since I fly CL scale with throttle control. I can put this on the ground, concrete or grass and it won't move.
Fred Cronenwett
CL scale
« Reply #20 on: July 18, 2009, 06:31:06 PM »
Some guys are just flat out geniuses. HB~>
Offline jim gilmore
« Reply #21 on: July 26, 2009, 01:58:23 PM »
Yes thats anrweal nice looking test stand using surplus stuff
Offline Warren Wagner
  • Bradenton, FL
« Reply #22 on: July 27, 2009, 07:30:21 PM »
You mention "folding", and here is folding.
This test stand is a Tatone mount, fastened to a piece of Melamine board, which is securely bolting to a metal, folding saw horse from Home Depot.
The saw horse is quite heavy, and is adequate weight for motors up to 35-40s.   Anything larger, I cozy up to some thing substantial and put a strong, solid rubber bungee chord around it and the saw horse.
A similar, smaller metal mount can be mounted on the opposite end of the saw horse to give you a range of motors that can be tested.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline Garf
    • Hangar Flying
« Reply #23 on: July 27, 2009, 09:56:04 PM »
I'm still watching this thread. I'm leaning to some sort of sawhorse type of stand so I can stand up to crank the engine rather than go down on my knees.
