Anyone found an affordable Down Draft sanding table? My nose is tired of balsa dust and I'm going to buy something.. Know I can build one but would rather buy an ARS (Almost Ready to Sand) rather than take the time to gather up the materials and build one.
Bob,
If you have a shop vac, you can make a sanding table so easily, quicker than it would take to order one in.
As I remember the one that Windy wrote about, the sanding table surface was a dropped ceiling grill for a fluorescent light fixture. Seems like it was about 2' x2' (panels are also available in 2' x4'), white plastic grill, with egg-crate squares approximately 3/4" than went all the way through the panel. I'll bet if you walked through any home improvement center, you would find something very close to that. You would probably want to "buff" the surface of the grill with steel wool or Sotch Brite to make sure there were no sharp edges that would damage your work.
I did a Google search but could not come up with any pictures to show you, but I'm sure you have seen them in the stores.
I believe Windy's base was a existing table or bench, and probably went to a central vacuum system. You could cut the ceiling grill to fit any size "box" that you might have, even an old drawer would work....cut the grill to fit, and drill a hole in one size for your shop vac.
Or you could construct a box specific to the job, and design it to fit your exact requirements and to fit the space that you have available. "Piece of cake", as they say.
Part of the fun of being a modeler is that you can make things that you need, and often times, make them better. Eric V just fabricated one for himself...maybe he will let you in on his design, as soon as he comes down off from 'Cloud Nine' for taking second in PAMPA Advanced at the KOI.
Cheers.
Warren Wagner
