  • July 17, 2025, 10:12:29 PM
Author Topic: looking at '75 fox combat spec. w/ smooth head. who knows about this year /model  (Read 1133 times)
Offline paulwells66
I"m eyeballing a '75 fox combat spec. w/ smooth head. who knows about this year /model.
This one has a square (not coffin) backplate. Thinking of using it with restrictor and vented tank in a super combat streak.
Was going to use a mccoy in this plane but I don't trust that engine
thanks
I am flying a Combat Streak with McCoy 35 Redhead.  Not as fast as with a Combat Special.  But still a lot of fun.  Use a uni-flo tank for good results. D>K
Offline paulwells66
That's just the problem...I already buried a vented tank in the fuselage so uniflow is not an option. I worry about the McCoy cutting out with the vented tank. What do you think?
Offline frank mccune
     I have a CS with a McCoy .35 RH and it is a great combination!
     Frank
Offline Richard Imhoff
Good motor on low nitro and 9" props but in the day on high nitro and 8" props they all broke the crankshafts.
 Good motor plenty of power on 10% just stay away from high nitro and high RPM's and the crank will stay in one chunk.
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Offline paulwells66
thanks!
Offline Lyle Spiegel
I have one of those. It was known as a "baldie". At this point, I will be glad if I could handle a combat streak with 9 inch prop on 10%. I have a Ringmaster running a OS 35S and it is a good workout. Hoping to build a Voodoo with my JCS as a challenge.
Lyle Spiegel AMA 19775
Offline Peter in Fairfax, VA
They all broke cranks.  Chucking up the crank in a lathe and cutting the bore smoother was thought to possibly help.  Maybe.
They ran great until the crank broke.  That was my experience.  Yes, 40% nitro was typical.
Peter
Online Howard Rush
The Black shafts were the worst.
The case would crack at the bottom of the front bearing, too.
Offline paulwells66
Yikes!  the seller would not be happy to hear all this lol. Maybe I"ll ask for a discount ;)
