  • July 18, 2025, 03:21:47 AM
Author Topic: logrithmic flap horn - ie Igor Burger's Max Bee plane  (Read 1092 times)
Offline Guy Markham
« on: September 20, 2015, 02:16:08 PM »
Has any one used this set up? if so what results vs regular system?  n~ Thanks, Guy
You only have to floss the teeth you want to keep!
Online Howard Rush
Re: logrithmic flap horn - ie Igor Burger's Max Bee plane
« Reply #1 on: September 20, 2015, 04:16:33 PM »
You mean other than the current US Nats, World, and European champions?  I've used it.  I think it allows you to get more optimal flap-elevator ratios for round and square maneuvers than having the same ratio for both.  It also reduces hinge moment for large control deflections,  allowing you to fly more accurate corners.  I'm not sure I am getting the max benefit from it, because I don't know how much the controls on my airplane move.  I have it installed in an Impact, which may have different flap deflections in maneuvers than a Max Bee.
