  • July 21, 2025, 06:35:33 AM
Author Topic: Tip Weight  (Read 937 times)
Online James Mills
Tip Weight
« on: March 31, 2011, 09:33:19 PM »
How much tip weight should allow for when building a 60 size plane (in other words, how big should I make the box)?
James
AMA 491167
Re: Tip Weight
« Reply #1 on: April 01, 2011, 07:52:08 AM »
Depending on the design, it should not exceed 2 ounces,  unless you fly carrier.   Build the box bigger than you think you will need.   H^^
Re: Tip Weight
« Reply #2 on: April 01, 2011, 08:17:37 AM »
How big should you make the box ?
I like about the size of a box of Matches. Thats a fair amount of lead.
Offline RC Storick
Re: Tip Weight
« Reply #3 on: April 01, 2011, 01:53:13 PM »
James
1 cubic inch
Re: Tip Weight
« Reply #4 on: April 03, 2011, 06:40:01 AM »
James,
When you look at the weights that are available from several sources they are 1/2" squares that fit into the 1" boxes with a center bolt. The tip weight boxes are available from Brodak or Tom Morris assembled or parts. Since the box itself weights about 1/3 to 1/2 oz (depends if it is lite ply or Birch ply) you don't normally need to much more for stunt.
Best,      DennisT
