  • July 17, 2025, 10:23:39 PM
Author Topic: When is the Hazelton contest?  (Read 887 times)
« on: May 20, 2021, 11:35:02 AM »
I looked on the Calendar here and it just shows birthdays.  Is there some other calendar I should be looking at?
So, when is the Hazelton, PA contest?
Thanks!
Re: When is the Hazelton contest?
« Reply #1 on: May 20, 2021, 01:43:39 PM »
Try the Events section. D>K
« Reply #2 on: May 20, 2021, 02:03:03 PM »
Nothing there.
So I repeat: does anyone know what dates the Hazelton PA contest is scheduled for?
Offline Bob Matiska
« Reply #3 on: May 22, 2021, 06:18:12 AM »
Bernie Suhamski ran the meet in Drums and he's here on SH. He has not been active here since last July, however. He posted a message about the meet in 2018 and asked if people wanted it to be moved to later in the summer because of the heat. I don't know what happened after that and don't know if there was a meet in 2019 and I'm sure there wasn't one in 2020. I sent him a message on FakeBook to see what's going on, but don't know how active he is there, either. I'll let you know if he responds.
Bob
AMA 56267
Offline Bob Matiska
« Reply #4 on: May 22, 2021, 11:31:10 AM »
I just received a response from Bernie. He's been running back and forth to North Carolina to help his folks, who are elderly and experiencing personal issues. He has not had time to set up a contest. He said maybe next year...
Bob
« Last Edit: May 22, 2021, 12:25:50 PM by Bob Matiska »
AMA 56267
« Reply #5 on: May 23, 2021, 06:23:09 PM »
Thanks!  I talked to a couple of his flying buddies at the Eastern shore contest this weekend and they said the same.
It was always a fun contest.  Hopefully, Bernie will be able to run it again after things get a bit less busy for him.
