  • June 24, 2025, 04:24:47 AM
Author Topic: Rattle Can Paint  (Read 1118 times)
Offline Stephen
  • Stephen Hollier 217629
Rattle Can Paint
« on: November 30, 2020, 09:19:36 AM »
Gents,
On my new plane I plan on using white rattle-can paint on the fuse and part of the wing. Will it be ok to spray auto base color over the rattle-can white? The auto base color will be utilized for trim. What rattle can paint do you suggest I use enamel or laquer and rustoleum or krylon?
Thanks for the help.
Offline Carl Cisneros
Re: Rattle Can Paint
« Reply #1 on: November 30, 2020, 10:46:30 AM »
Stephen;
Before you spray the plane I would HIGHLY suggest you use a test piece to see if the auto paint is compatible with
the spray can paints.
Carl C
Carl R Cisneros, Dist IV
Control Line RB
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #2 on: November 30, 2020, 04:28:43 PM »
You can use Dupli-Color spray paint and then put auto two part
clear on it with no trouble. Dupli-Color is available at almost any
auto parts retailer.
