  • July 17, 2025, 09:10:57 PM
Author Topic: Line winder.  (Read 5474 times)
Offline John Rist
Line winder.
« on: August 26, 2024, 11:28:58 PM »
Does anyone still make and sell a line winder?  The kind that fits a standard line reel.
Offline John Rist
Re: Line winder.
« Reply #1 on: August 28, 2024, 10:09:28 PM »
I couldn’t find a source for a line winder so I decided to clone the one I had.  The aluminum bar stock and maple rod stock came from McMaster-Car.  The 1/16” plywood disk and screws came out of my junk box.
Clamping the bar in a vice and taping it with a hammer bent the Aluminum bar.  The angle of the dangle was achieved by aliening it up on the drawing.
The 7/8” round rod turned out to be a tight fit in the center hole of the line reel.  I drilled the wood screw hole in one end and inserted a wood screw leaving about a ½” of screw sticking out.  I sawed off the head of the screw.  This left a stud sticking out that allowed me to chuck up the rood in my drill press.  I then sanded the rod until I had a loose fit in the center hole of a line reel.
By the way the 1.5” diameter 1/16” plywood disk is something that I added to the winder that I bought years ago.  On some of my line reels the winder tended to cock sideways in the reels oversize center hole.
As it says on the drawing, I sized the holes to fit the screws I found in my junk box.
The pictures are of the finished winder and the drawing of the parts needed to assemble one.
What got me going on this project is we have a new member in our club.  I am working with him to help him come up to speed.  He flew years ago and is getting back into the hobby.  I was surprised that no one sells a line winder.
Anyway it was fun project.  As it turns out it wasn’t that hard to do.
Offline Perry Rose
Re: Line winder.
« Reply #2 on: August 29, 2024, 05:34:43 AM »
A one inch long piece of plastic pipe that fits over the handle to hold the reel steady while winding.
Re: Line winder.
« Reply #3 on: August 29, 2024, 05:49:38 AM »
As a one-up,   I went to watch a combat contest this spring.   One guy had something like what you have but attached a small electric screwdriver (battery) to it and just pressed the button.  Winds the line easy and pretty fast.   I have a screwdriver like that I don't use for anything.......
Re: Line winder.
« Reply #4 on: August 29, 2024, 06:13:07 AM »
   I just use my fingers.  A handle is nice, and looks like it would lay flat in a flight box. Maybe after I get past a dozen other projects.
Offline John Rist
Re: Line winder.
« Reply #5 on: August 29, 2024, 09:05:27 AM »
Speaking of one up. In the past we have converted kite line reels into control line reels.  The winder is built in.   y1
« Last Edit: August 29, 2024, 01:02:06 PM by John Rist »
Re: Line winder.
« Reply #6 on: August 29, 2024, 09:52:29 AM »
John, Brodak line reel comes with the plastic center post and you just use your finger in the outer hole to wind. (https://brodak.com/015-x-2-x-60-insulated-braided-steel-control-line.html)
Best,  DennisT
Re: Line winder.
« Reply #7 on: August 29, 2024, 09:56:08 AM »
     How you keep tension on it? Sounds like a formula for a bird's nest.
Offline John Rist
Re: Line winder.
« Reply #8 on: August 29, 2024, 10:02:40 AM »
Best,  DennisT
Yes but only on the bigger reels.  The standard reel is still a pain to wind up the lines with ought a winder.
Re: Line winder.
« Reply #9 on: August 29, 2024, 02:24:24 PM »
As I recall he reeled with handle attached.  The drag on the ground was enough.  I wind by hand (still) but always leave the handle on too and it’s enough.   Actually never understood why anyone takes the handle off anyway-as long as you have the lines and handle dedicated to one airplane it seems pointless.
Re: Line winder.
« Reply #10 on: August 29, 2024, 02:31:59 PM »
Here’s the little bugger.  I forgot- it’s rechargeable.
Offline John Rist
Re: Line winder.
« Reply #11 on: August 29, 2024, 04:18:55 PM »
That's what I need. Another item that needs charging before I go to the field.   LL~
Online Motorman
Re: Line winder.
« Reply #12 on: August 29, 2024, 04:55:01 PM »
You can wrap the lines around your leg to control the tension as you wind them up. I though everybody did it that way.
Re: Line winder.
« Reply #13 on: August 29, 2024, 05:12:40 PM »
Now we understand about you..........
Offline Reptoid
Re: Line winder.
« Reply #14 on: August 29, 2024, 08:17:13 PM »
     I have never understood the need for anything other than a "Pylon" type reel for any lines. Been flying for over 65 years and can still wind in a set in under 30 seconds using one finger for a pivot and one finger to wind. I've tried and owned other reels and methods but this simple way always works, stores easier than bulkier ones and the reels hold everything from 1/2 A lines to 70 footers. I leave one end connected to apply minimal tension for winding and do the same to unwind.
       Don
       AMA # 3882
Re: Line winder.
« Reply #15 on: August 29, 2024, 08:38:21 PM »
I wind the lines from the handle end, toward the plane. Benefits? 1) The plane stays where it sits, unlike the handle would, which I don't like dragging across the pavement or through the weeds. This also takes care of the tension while winding quandary. 2) The handle fits in my hip pocket. 3) By removing the handle, the lines and handle fit in a quart ziplock bag and then fit fine in the top of my cheezy plastic tool box. 4) I typically remove the handle and wind the lines up to the plane when leaving it in the pits, so my lines don't get stepped on or otherwise mutilated.
There are two ways to do this. I like mine, and you like yours. But I'm right, so....  LL~ Steve
« Last Edit: October 23, 2024, 11:50:39 PM by Steve Helmick »
Offline Perry Rose
Re: Line winder.
« Reply #16 on: August 30, 2024, 05:55:37 AM »
I stake the handle to the ground when winding the lines. Also when retrieving the plane after a flight. An absolute must when flying alone.
Offline Doug Moisuk
Re: Line winder.
« Reply #17 on: August 30, 2024, 11:18:04 AM »
I step over the lines and the lines are between my legs for tension. Also cleans the lines. Works with jeans but not white pants. 🤓
Doug Moisuk
MAAC 3360L
Online Howard Rush
Re: Line winder.
« Reply #18 on: August 30, 2024, 05:46:15 PM »
Dan Rutherford made me a nice one. It’s in a pawn shop in Dallas.
Offline Curt D Contrata
Re: Line winder.
« Reply #19 on: August 30, 2024, 06:53:02 PM »
Here is mine…
Promised I would not say who made it.
Miss you Mr. Patriot…
Curt
Re: Line winder.
« Reply #20 on: August 30, 2024, 06:57:51 PM »
I know,,, No hard point, but this is over 20 years old and good enough to make top 5 in the day.
I think the inner core is wrapped in unobtanium.
Curt
Re: Line winder.
« Reply #21 on: August 30, 2024, 08:58:01 PM »
Maybe you went to that pawn shop in Dallas?
Offline Istvan Travnik
Re: Line winder.
« Reply #22 on: August 31, 2024, 05:27:59 PM »
Dear Friends,
I simply cannot understand, that 70 years were not enough for invent the THIRD hole in the reel?!
When you have another upwinding hole on the opposite side, you can very quickly, and absolute safely roll up the lines, with a "bycicle-driving-like" movements with your left and right pointer fingers.
(You can easily drill the third hole: buy a 20 mm dia "crown drillhead", and some drops of water... )
I made a number of different designs: First ones made of open reel taperecorder's reel, still in 1969, now I can collect empty filament-reels as raw material from  3D printer colleagues: very strong, water clear, machinable by discsaw, lathe, milling machine and crown-drill. Beautifully gluable with some drops of chloroform... (It is Polycarbonate)
On demand I put photos up, just ask me!
istvan
« Last Edit: August 31, 2024, 06:28:48 PM by Istvan Travnik »
