  • July 20, 2025, 08:22:45 AM
Author Topic: Line length  (Read 3512 times)
Offline sadams714441
Line length
« on: May 14, 2015, 07:31:42 PM »
Any suggestions for the line length for primary force with 40 on it
Steve Adams
Re: Line length
« Reply #1 on: May 14, 2015, 10:02:22 PM »
   I built mine as per instructions and powered originally with an LA.25. Line length was what it called for in the instructions along with line spacing. Model flew "right off the board" like that. I upgraded to an OS.32F and when I got the engine "happy" in test flights, I think I went a foot and a half or two feet longer than the instructions. I measure line length  from the handle to the center line of the fuselage, and I think Mike Pratt called it out that way in the instructions also. I would start out two feet longer than the instructions. You can always shorten the lines if necessary. They haven't as yet invented a line stretcher. It helps A LOT to have an idea of what lap time you are comfortable at and have that in mind during the trimming process. That will be factored in to what speed the airplane will need to fly and perform well at.
    There really is no magic line length or lap time/speed. You have to determine that by what you see and feel.
  Good luck and have fun,
Re: Line length
« Reply #2 on: May 15, 2015, 07:30:25 AM »
With a 40 I'd go for 65' handle to thrust line.
Offline Allan Perret
  • Proverbs
Re: Line length
« Reply #3 on: May 18, 2015, 11:18:29 AM »
Mine does good on 62'x.015"  e2e with a Magnum36XLS.   I would start off with 60' and go up if you think it can handle more.
« Last Edit: May 18, 2015, 03:03:33 PM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Gerald Arana
Re: Line length
« Reply #4 on: May 18, 2015, 12:02:27 PM »
60 feet eyelet to eyelet.  ;D
Jerry
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Line length
« Reply #5 on: May 18, 2015, 02:11:01 PM »
Jerry
This sounds more reasonable, I fly my 62 powered stunt ship on 62's or 63's depending on conditions.
Offline Mike Haverly
Re: Line length
« Reply #6 on: May 18, 2015, 10:14:36 PM »
Some Impacts should be flown on lines about 2 feet shorter than the ones being used recently. :##
Re: Line length
« Reply #7 on: May 18, 2015, 10:43:44 PM »
Offline Dennis Moritz
Re: Line length
« Reply #8 on: May 18, 2015, 10:56:55 PM »
Primary Force is on small light side (can be) of 40 power. Which can be great combo. Depending on engine tune, head gaskets, venturi size, prop, fuel, and so forth, optimum line length will vary. Run engine where it's happy. If you're lap times are faster than you like, reduce venturi size or lengthen lines. I'd try 60' .015s, eyelit to eyelit, for a start.
Re: Line length
« Reply #9 on: May 18, 2015, 11:07:43 PM »
I presume Dennis means "eyelid to eyelid".  His imagery is sometimes difficult to understand.
Re: Line length
« Reply #10 on: May 19, 2015, 12:17:04 AM »
How 'bout that. Auditory illusion allusion. Happens all the time.
Re: Line length
« Reply #11 on: May 19, 2015, 12:18:59 AM »
How'd it get pass Sparky's spell checker?
Re: Line length
« Reply #12 on: May 19, 2015, 12:19:58 AM »
O God another one. Passed.
Re: Line length
« Reply #13 on: May 19, 2015, 10:15:11 AM »
People are so picky.  Even at my age I knew what he meant. VD~
Re: Line length
« Reply #14 on: May 19, 2015, 02:58:44 PM »
Offline David Hoover
Re: Line length
« Reply #15 on: May 19, 2015, 03:33:17 PM »
And I always thought that those little thingies at each end of our control lines were called "eyelets".  How silly of me.
Best, Hoovie
Re: Line length
« Reply #16 on: May 20, 2015, 10:06:29 AM »
Not so fast, Doc.  Read this and tell me what he meant: http://www.amazon.com/Something-Hold-Nine-Theater-Pieces/dp/0935992014/ref=sr_1_1?ie=UTF8&qid=1432069004&sr=8-1&keywords=dennis+moritz
Will have to get the book and read.  Of course it may be above my level of intelligence.
