  • July 16, 2025, 04:44:22 PM
Author Topic: Line length  (Read 1115 times)
Offline sadams714441
Line length
« on: October 01, 2014, 03:46:16 PM »
What is good starting point as far as line length for nobler or tudor
Steve Adams
Re: Line length
« Reply #1 on: October 01, 2014, 04:08:19 PM »
I fly a Fancherized Twister on 65' lines.  That's probably a bit long, but I put it on those lines and never felt a need to try something shorter.
Conventional wisdom would put your line length between 60' and 62' if you're using a Schnueurle-ported 36 to 46 sized engine.
Offline Andrew Saunders
  • 2013 Nats
Re: Line length
« Reply #2 on: October 01, 2014, 06:56:39 PM »
try three sizes. 58', 60', and 62'. Try each length with the engine set to where its happy. you will want anywhere from a 5.2 second lap to a 5.5 second lap. On my Nobler, i found it flies exactly the lap time i need on 60' lines.
Offline Dane Martin
  • heli pilot BHOR
Re: Line length
« Reply #3 on: October 01, 2014, 07:25:37 PM »
sounds like we'll all be in agreement here! i have a nobl-arf with an OS .40 LA  and i fly it on 60' lines. that's with a 10x5 prop
Offline Jim Hoffman
Re: Line length
« Reply #4 on: October 01, 2014, 07:50:52 PM »
Mr. Saunders has it right.  If you can make it work on the longer lines (60'), Lucky you.
My Nobler is competitive at 57.5 foot lines,  eyelet to eyelet.
Aerotiger 36, 43 Oz.   Nice line tension there.
Jim Hoffman
Offline Ward Van Duzer
Re: Line length
« Reply #5 on: October 02, 2014, 01:48:49 PM »
Interesting!
No one mentioned solids or braided, # of braids. or Diameter?  n1
Ward
Re: Line length
« Reply #6 on: October 02, 2014, 03:46:52 PM »
I think Bret said one time to run the shortest lines you feel comfortable with. My 52 version Nobler flew well with a Fox 35 on 58' eye to eye.
Re: Line length
« Reply #7 on: October 02, 2014, 04:10:48 PM »
I don't think any of those things have a great impact on the line length choices.
Re: Line length
« Reply #8 on: October 02, 2014, 09:59:16 PM »
I believe it has a lot to do with engine size and power/weight ratio. The KISS! (Fancherized Twister) at 47 oz with a Magnum XLS .36 was a lot better on 58' i2i than 59' i2i. After I gave it to Tim, he tried to fly it on 65' lines, I bet! It didn't last long after that.  LL~ Steve
