  • July 16, 2025, 07:13:54 AM
Author Topic: Line Connectors  (Read 1867 times)
Line Connectors
« on: January 21, 2023, 02:46:50 PM »
I am totally frustrated trying to find a source for line connectors.  I need 12-16 of the "Test" medium (1") size to make up a series of "Spectra" lines.  EBay is either out of the size or grossly overpriced.  Amazon has none, Horizon and Tower don't carry them, Okie is "on backorder", Brodak has the wrong type and RSM does not have the quantity I need.  Not sure I like the "New Normal".  I am pretty sure someone has them.  I suppose I could use rings (where so I get the small ones) and just the clips I have but that is a last resort. Any suggestions?
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: Line Connectors
« Reply #1 on: January 21, 2023, 03:27:58 PM »
I buy these connectors from a fishing supply source. Get size 5 unless you are flying 1/2a models.
https://www.lurepartsonline.com/Mc-Rosco-Snaps
Fishing supply sources that good stuff, just don't them you are buying it for a model airplane, they won't understand. I use to buy insulated fishing leader from these sources. But now I can use uncoated flying lines now that we fly CL scale with 2.4 Ghz for the wireless throttle control.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Re: Line Connectors
« Reply #2 on: January 21, 2023, 03:36:30 PM »
If you don't wrap your lines these are also handy, get the smaller sizes for our lines
https://www.lurepartsonline.com/Double-Sleeves?quantity=1&custcol11=153&custcol17=5
Fred Cronenwett
Re: Line Connectors
« Reply #3 on: January 21, 2023, 03:37:57 PM »
These are the single crimp tubes for building lines without wrapping the ends
https://www.lurepartsonline.com/Leader-Sleeves?quantity=1&custcol11=129&custcol17=5
Fred Cronenwett
Re: Line Connectors
« Reply #4 on: January 21, 2023, 03:49:25 PM »
Fred
Thanks Fred, those look like they will work.  I was hoping to find the simple elipse type but those look like they are round and smooth enough to take a braded line knot and not cut it up.
I will order some.
ken
Re: Line Connectors
« Reply #5 on: January 21, 2023, 04:13:17 PM »
I have to use my fingernail to open up the clip, I have these in my kit for line making.  At least the price is better than the hobby shop sources.
Fred
Fred Cronenwett
Offline John Carrodus
Re: Line Connectors
« Reply #6 on: January 23, 2023, 03:06:28 AM »
Lack of supply, correct size, busting fingernails , damaging line,etc has lead me to simply make my own. I use piano wire of suitable strength, bend in the shape of a staple - after its been stapled. Cut some plastic tubing to slide over to lock in lines and bingo. Cheap easy to make ( once you messed up a few getting it right) way stronger than you need , and you can vary the length if your lead outs are outa whack by a few mm for that particular model.
Re: Line Connectors
« Reply #7 on: January 23, 2023, 06:16:00 AM »
Why not MBS supply.?  Melvin stocks these in two or three sizes.
Offline BillLee
Re: Line Connectors
« Reply #8 on: January 23, 2023, 06:50:06 AM »
Or Jim Lee at Lee Machine shop: sells line clip bender and the wire, instructions in Stunt News May/June 2006
Bill Lee
AMA 20018
Re: Line Connectors
« Reply #9 on: January 23, 2023, 07:10:23 AM »
One is on the way!
Offline Brent Williams
Re: Line Connectors
« Reply #10 on: January 23, 2023, 09:40:00 AM »
Ken, add the Xuron 2193F wire cutters to your shopping list.  With the guides, these align the wire perpendicular to the jaws and make a perfect 90° cut which requires no filing or burr dressing afterward.  I've made around 500 clips using these cutters and wouldn't want to use anything else!
https://www.amazon.com/Xuron-2193F-Music-Cutter-Retaining/dp/B000FOJLEC
Offline Ara Dedekian
  • Ara Dedekian
Re: Line Connectors
« Reply #11 on: January 23, 2023, 10:44:25 AM »
      Thanks for the link Fred, I just ordered both sizes. I've been drifting back to a cable handle because it's difficult to get an exact adjustment on a hard point handle with the Lee clips. Not sure if I have his fine thread bender but I'll have to mill some in-between flats on the nut for finer increments on the clip lengths.
      Ara
Offline Dave Harmon
Re: Line Connectors
« Reply #12 on: January 23, 2023, 11:35:15 AM »
This clip bender tool is one of the most important tools I have.
It works so slick and quick that I am never gonna use any other type of clip.
One time I destroyed a Bob Palmer 'MARS' because one of those stinking 'LUX' clips came open.
I also gave up on those clips that broke all my fingernails and/or required pliers to get open.
Anyway....a little practice with the Lee mfg bender and you can easily make any length.
I got tired of guessing at the length of the clip so I developed a formula to make the wire the correct length before bending.
This works really great and eliminates the guessing.
I use a hard point handle and OAKIEAIR lines that are always made equal length and then adjust the clip/s that stay on each airplane lead outs.
Also I use equal length clips that stay on the handle.
I like the feel of the same handle when I fly different airplanes.
This tool eliminates dedicated lines and handles to specific airplanes.
Re: Line Connectors
« Reply #13 on: January 23, 2023, 11:53:24 AM »
I stock the same style clips from Sullivan/Pylon https://sullivanproducts.com/product/80-pound-test-line-connectors/ as made by the Jim Lee produced - Derek Moran designed clip bender. My preference is to use two stock Sullivan clips on the airplane end, and one Sullivan and one custom (longer) clip on the hard point handle. Each airplane should have its own handle, because we need to adjust spacing to suit each. Full adjustability is a huge leap forward.  D>K Steve
Re: Line Connectors
« Reply #14 on: January 23, 2023, 11:59:22 AM »
      Ara
Howard had Jim Lee do that, so the clips could be made in 1/32" increments, instead of the standard 1/16" increments. Nobody around here thought it would prove to be better or needed. Maybe Howard will comment?  D>K Steve
